Unlock KE970 done hello thx to infinity team.............................................. .......................... COM55 [VCP0] selected Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta_20081019-102044.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta2_20081019-102046.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sec_35030526000000100_20081019-102049.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081019-102050.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 0197 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 24 sec |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
