Old 12-25-2008, 22:17   #1 (permalink)
limem2003's Avatar
Member: 108627
Thanks Meter: 307
Unlock KE970 done
hello
thx to infinity team.............................................. ..........................
COM55 [VCP0] selected
Device: LG-KE970
Checking data, wait...
Action: unlock
direct unlock
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 02
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0089:88B0
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta_20081019-102044.B1E.bin
reading [eeprom-sta2]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta2_20081019-102046.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading [eeprom-sec_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sec_35030526000000100_20081019-102049.B1E.bin
reading [eeprom-complete_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081019-102050.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 0197
Done
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 24 sec
The Following User Says Thank You to limem2003 For This Useful Post:
Old 12-26-2008, 10:49   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
problem unlocking ke970 mobilecraker FuriousGold 7 12-15-2007 16:06
First try with Vygis to unlock KE970 justmegt VygisToolbox 6 12-05-2007 01:10
Unlock KE970 with orig. cable alejandroveliki VygisToolbox 4 11-16-2007 15:24
.::Successfully Unlock Ke970 Using Furious Gold::. jhepoy_org FuriousGold 4 10-11-2007 01:55
ult-pro can unlock ke970 nurudeen hamza ULT PRO 3 08-27-2007 11:01
Page generated in 0.16495 seconds with 10 queries
