05-27-2007, 15:10 | #1 (permalink) |
Junior Member Join Date: Apr 2007 Location: french guiana
Member: 486970 Status: Offline Thanks Meter: 2 | unlock konka a26m i try unlock a konka a26m but is not fonction why ? here message COM1 selected Device: Konka A26M Checking data, wait... Action: Unlock Boot... Press and HOLD Power button now ! error: boot error[01] can't detect device Release Power button now ! In case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 39 sec Remove/Install battery now ! can you help me plz |
05-27-2007, 18:00 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure you using right com port? battery is charged cable made by this scematic? Cable name: Spice-S800 KEYBOARD TOP 1.........18 9: Gnd 10: phone Tx 11: phone Rx |
06-02-2007, 16:30 | #3 (permalink) |
Member: 486970 Status: Offline Thanks Meter: 2 | Thanks a lot for your answer. Still can't sp unlock phone. Phone is not recognized. I tried with box power off, f-bus mode, com1, auto baud rate on boot, RTS LED is on, CTS LED blinks, nothing happens phone turns on when I keep the ON Key pressed. I don't think there's a problem with cable, tried with two different cables and nothing, having same problem with sony W810 phone. Am I messing something up here? |
06-02-2007, 18:31 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! box switch in position power ON, F-bus left RJ45 connector phone powered OFF set com port number like you see it in device manager (i dont think it is com1 like you wrote above) auto baud rate. please check if you apply all methinoed above |
can't unlock konka a26M | frekko971 | Infinity-Box | 1 | 04-14-2007 05:40 |
unlock konka a26m | frekko971 | Infinity-Box | 1 | 04-12-2007 07:50 |
please unlock konka a26m. | vexcells | Infinity-Box | 1 | 03-30-2007 08:21 |
Konka A26m how to unlock it?? | starcell | Various | 7 | 03-02-2007 17:57 |
06 Dec 2006: Konka A26M model supported | InfinitySupport | Infinity-Box | 6 | 01-19-2007 06:35 |
