08-20-2008, 10:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Mombasa Age: 48
Member: 722683 Status: Offline Thanks Meter: 33 | unlock kp235 Device: LG-KP235 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button! Flash: 89881600010001:89881600000000 Flash: 89881600010001:89881600000000 Id: 00005258 Error: hardware is not supported, errorcode#01 Boot Fail Finished, time used: 14 sec Remove/Install battery now! this is the error message am getting.plz help me unlock this phone |
08-20-2008, 10:37 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | Infinity has some errors with KP230,KP235...you can try with free solution here(tested and worked)http://www./showth...ighlight=KP230 |
09-11-2008, 09:20 | #7 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | KP235 unlock OK with ke500 cable COM3 [VCP0] selected Device: LG-KP235 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352127023154920 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127023154920_LG-KP235_20080911-091643.B1E.bin .... Check flash Done Check space... current eeprom imei: 352127023154920 .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 74 sec Remove/Install battery now ! |
The Following User Says Thank You to abakwa For This Useful Post: |
09-11-2008, 09:23 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
FREE UNLOCK kp235 | renaldo2 | LG | 56 | 04-05-2015 22:13 |
Problem with unlocking KP235 | robbie | VygisToolbox | 7 | 01-31-2009 13:06 |
How to unlock kp235 via pinfinder?? | khem | Infinity-Box | 5 | 11-12-2008 12:00 |
Unlock Kp235? | zablon | FuriousGold | 12 | 10-19-2008 12:06 |
witch cable kind to unlock kp235 | galaxyou | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 06-16-2008 22:19 |
