02-16-2010, 16:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: romania
Member: 201764 Status: Offline Thanks Meter: 76 | unlock motorola wx395 I see that this model is supported,but much more innformation about unlock procedure can somebody tell me,pinout ,cable or someting. Tnks in advanced. |
02-16-2010, 16:50 | #2 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 Unlock procedure: connect cable to phone, select COM port, press "sp-unlock" button and follow instruction given by software. | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
02-18-2010, 18:01 | #3 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Serbia
Member: 18423 Status: Offline Thanks Meter: 26 | Worked. COM7 [VCP1] selected module v3.16 Device: Motorola-WX395 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2C03:A005 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.3B9B6 AB9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D5D1415C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 3B9B6AB9 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 27G provider: M395X-2BTBHR1 customization: CJ27YV72 customization: XJ27YV72 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... max address is too big, should be recalculated: 08BF4000->00006F54 error: can not recalculate address range, allowed offset is too small: 00006F54 error: can't calculate security area (sec info, part #1) security area (sec info, part #2) calculation... identification header detected customization: XJ27YV72 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ27YV72 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_3B9B6AB9_D5D1415C_20100218-174932.B0X.bin Finished, time used: 3 min 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 3 Users Say Thank You to space1 For This Useful Post: |
06-19-2010, 12:36 | #4 (permalink) | |
No Life Poster Join Date: Nov 2009
Member: 1158839 Status: Offline Thanks Meter: 127 | Quote:
with wich cable you unlock this phone? | |
06-19-2010, 17:56 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
03-08-2011, 19:11 | #12 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 44
Member: 388207 Status: Offline Thanks Meter: 221 | bro always check for latest udate in infinity shell as this is the only team providing more or less daily updates you can earn wonders if u get yourself updated and also far ahead from others |
The Following User Says Thank You to Deepakranasaria For This Useful Post: |
03-26-2011, 09:23 | #13 (permalink) |
Junior Member Join Date: Sep 2009 Location: vietnam
Member: 1127626 Status: Offline Thanks Meter: 1 | unlocked motorola wx395 i was unlocked motorola wx 395 by infinity selec comport by spiderman box cable L08a this is log COM42 [VCP2] selected module v3.62 Device: Motorola-WX395 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! error: boot initialization step #3 failed: 01 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001303:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.84F31 5C8.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D5D1415C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 84F315C8 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 27G provider: M395X-2BALGR1 customization: CJ27YG74 customization: XJ27YG74 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YG74 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YG74 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_84F315C8_D5D1415C_20110326-151501.B0X.bin Finished, time used: 3 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to tienquyen For This Useful Post: |
04-10-2011, 15:38 | #14 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Quote:
thanks friends it working also me.. | |
The Following User Says Thank You to fertxter For This Useful Post: |
30 Jan 2010: Motorola-WX395 model supported | YellowBoss | Infinity-Box | 73 | 05-10-2011 15:52 |
Infinity-Box: non-stop updates: Motorola-WX395 model supported | bunty2008 | Infinity-Box | 1 | 01-30-2010 21:06 |
Infinity-Box: non-stop updates: Motorola-WX395 model supported | YellowBoss | Service Products News & Updates | 0 | 01-30-2010 11:56 |
Motorola WX395 it's possible to be unlocked?!? | Burebista | Infinity-Box | 8 | 01-29-2010 20:13 |
motorola software update locked my motokrzr k1 | martindale024 | Motorola P2k | 0 | 05-01-2008 02:20 |
