10-29-2007, 09:18 | #2 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
well that's all sorry bad english br notgood | |
10-29-2007, 12:54 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Wait... Current model: Panasonic X400 Ready COM1 [Serial0] selected Device: Panasonic X400 Checking data, wait... Action: read eeprom Done[10] Boot... Press Power button now ! ==== log opened: [10/29/2007 12:00:23 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.32 error: Dongle not connected ==== log opened: [10/29/2007 12:00:50 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.32 error: Dongle not connected ==== log opened: [10/29/2007 12:02:17 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.32 S/N: 2682:010C Wait... Current model: Panasonic X200 Ready COM4 ready COM4 [VCP0] selected Device: Panasonic X200 Checking data, wait... Action: read eeprom Done[10] Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0089:8854 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071029-120426.0CE.bin loading data... data loaded Reading [eeprom-sec]... file saved: backup_eeprom-sec_20071029-120429.0CE.bin backup critical area Done Check memory... Reading [eeprom-complete]... file saved: backup_eeprom-complete_20071029-120450.0CE.bin Completed Finished, Remove/Install battery now ! Time used: 36 sec Phone must be in TEST-MODE: * + # + Power Connecting, wait... Connection Fail Finished Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... imei: 354082000838474 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.02 MMI ver: Mmi:X200PA19.LP2425.ANM_rev02,Jan20200515:20:51 Reading [eeprom-sec_354082000838474]... file saved: backup_eeprom-sec_354082000838474_20071029-120632.0CE.bin Reading [eeprom-sta_354082000838474]... file saved: backup_eeprom-sta_354082000838474_20071029-120635.0CE.bin Done Finished Phone must be in TEST-MODE: * + # + Power Connecting, wait... Connection Fail Finished Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... imei: 354082000838474 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.02 MMI ver: Mmi:X200PA19.LP2425.ANM_rev02,Jan20200515:20:51 Reading [eeprom-sec_354082000838474]... file saved: backup_eeprom-sec_354082000838474_20071029-121018.0CE.bin Reading [eeprom-sta_354082000838474]... file saved: backup_eeprom-sta_354082000838474_20071029-121020.0CE.bin startup mode confirmed Done Finished Phone must be in TEST-MODE: * + # + Power Connecting, wait... Connection Fail error: wrong connection Finished Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Imei: 354082000838474 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.02 MMI ver: Mmi:X200PA19.LP2425.ANM_rev02,Jan20200515:20:51 Reading [eeprom-sec_354082000838474]... file saved: backup_eeprom-sec_354082000838474_20071029-121105.0CE.bin Reading [eeprom-sta_354082000838474]... file saved: backup_eeprom-sta_354082000838474_20071029-121107.0CE.bin Resetting... Done Finished Current model: Panasonic X200 Current model: Panasonic X400 Loading file v.01... X200PA14_MAIN.0CM.bin loaded Current model: Panasonic X200 Loading file v.01... X200PA14_FFS_ASUU_rev02_LP2225_Ee_Lv_Lt_Ru_Ukr.0CF .bin loaded Loading file v.01... X200PA14_LP_ASUU_rev02_LP2225_Ee_Lv_Lt_Ru_Ukr.0CP. bin loaded Loading file v.01... X200PA14_MAIN.0CM.bin loaded COM4 [VCP0] selected Device: Panasonic X200 Checking data, wait... Action: flash write Done[10] Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0089:8854 Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071029-124400.0CE.bin loading data... data loaded Reading [eeprom-sec]... file saved: backup_eeprom-sec_20071029-124401.0CE.bin Reading [eeprom-dyn]... file saved: backup_eeprom-dyn_20071029-124415.0CE.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: FFS-1/Customization Writing: FFS-1/Customization Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 1895 sec Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... imei: 354082000838474 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.01 MMI ver: Mmi:X200PA14.LP2225.ANM_rev02,Oct18200412:16:12 Reading [eeprom-sec_354082000838474]... file saved: backup_eeprom-sec_354082000838474_20071029-132340.0CE.bin Reading [eeprom-sta_354082000838474]... file saved: backup_eeprom-sta_354082000838474_20071029-132343.0CE.bin No active locks found. Done Finished i unlock this phone with and without tick unlock in ant case and fix startup mode but no success how i can unlock infinity support |
10-30-2007, 09:58 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You can think all that you want but in fact it's supported. Just make "search" in this forum and you will see that it's better to search instead think. try again, try like x60 or like x400, check phone hardware. It's ordinary beginner's mistake to write "not supported, not work" instead of make "search". |
10-20-2008, 09:54 | #10 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Here
Member: 39196 Status: Offline Thanks Meter: 126 | it's easy to do just select model x200 and do unlock. Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... imei: 354082005156690 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.01 MMI ver: Mmi:X200VA10.LP0121.ANM_rev05,Oct15200403:25:49 reading [eeprom-sec_354082005156690]... file saved: D:\Program Files\InfinityBox\Pana01\Panasonic-X200_eeprom-sec_354082005156690_20081020-105241.0CE.bin reading [eeprom-sta_354082005156690]... file saved: D:\Program Files\InfinityBox\Pana01\Panasonic-X200_eeprom-sta_354082005156690_20081020-105245.0CE.bin Found: Network Done Finished |
The Following User Says Thank You to fadhel For This Useful Post: |
10-20-2008, 15:10 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
01-25-2010, 07:43 | #12 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India Ranchi
Member: 756180 Status: Offline Sonork: 100.1582554 Thanks Meter: 56 | Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... imei: 354082002472710 SEC ver: 01.21g(0002) SW ver: 00.00:18:22:C04.01 MMI ver: Mmi:X200PA14.LP1325.X200ANRUA141025,Oct18200412 reading eeprom-security_354082002472710... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X200_eeprom-security_354082002472710_20100125-121125.0CE.bin reading eeprom-static_354082002472710... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X200_eeprom-static_354082002472710_20100125-121127.0CE.bin No active locks found. Done Finished NOT SUCCESSFULL UNLOCKING HOW TO UNLOCK PLZ SEND DETAILS Y TELL ME SUPPORTED YA NOT SUPPORTED |
01-25-2010, 11:14 | #13 (permalink) | |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
Phone Showing Invalid Sim Or What ? If Showing Invalid Sim Than I Think But Not Sure Possible U Cannot Fix It Regards. UMER | |
panasonic x200 unlock help for infinity???? | firrozkhan_00 | Panasonic | 4 | 06-14-2008 16:10 |
panasonic x200 is there free unlock? | Rezn | Panasonic | 1 | 10-05-2007 07:36 |
CB2000 unlock panasonic x200 | chris2007 | Panasonic | 0 | 07-04-2007 04:41 |
panasonic X200 unlock 10000% | patric | Panasonic | 26 | 02-06-2006 12:16 |
panasonic X200 no sim accepted after unlock | wabou | Panasonic | 1 | 01-28-2006 20:45 |
