Old 10-17-2014, 21:55   #1 (permalink)
Member: 128745
Thanks Meter: 16,936
Unlock Samsung Note 4, ALPHA AND G800 with DT Samsung Client
There is a small battery trick to be followed in order to unlock Samsung G800 . NOTE 4 AND ALPHA USING DT SAMSUNG CLIENT and RJ45 / UART Cable
BATTERY TRICK TO UNLOCK G800 BELOW
BATTERY TRICK TO UNLOCK NOTE 4 AND ALPHA BELOW
The Following 10 Users Say Thank You to Infinity-Box For This Useful Post:
Old 11-15-2014, 20:17   #2 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
when u will update unlock solution of reactivation lock (samsung account bypass) ?
Old 11-24-2014, 09:21   #3 (permalink)
simcityreal's Avatar
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
G530H Successfully Unlock Via This Method.....Congrates Team......
Model: SM-G530H
HWID: CQN00E78EC29391
Imei: 357213xxxxxxxx
Starting unlock process.
Msladdress READED OK.
Sending data to server.
Sending Authorization to the phone.
Phone authorized OK.
Checking status of simlock.
Simlock status: 00004000
Unlock Done.
If phone ask for code, enter 00000000.
Restarting phone.
The Following User Says Thank You to simcityreal For This Useful Post:
Old 11-24-2014, 11:17   #4 (permalink)
Member: 128745
Model: SM-G530H
Unlock Done.
Restarting phone.
wich method did u try the G800 or Alpha ?
Old 11-25-2014, 18:20   #5 (permalink)
saber1985's Avatar
Member: 714523
Thanks Meter: 22
please add Samsung account reactivation solution on credite
Old 11-26-2014, 14:00   #6 (permalink)
tuhingr's Avatar
Member: 152752
Sonork: 100.1581661
Thanks Meter: 182
After using then method then working well
Model: SM-G530H
HWID: CQN00CB56C22991
Imei: 357213060
Unlock Done.
Restarting phone.
Old 11-27-2014, 06:40   #7 (permalink)
Member: 1417201
Sonork: 100.1626868
Thanks Meter: 32
which one can use unlock g530h pls help team
Old 11-29-2014, 12:21   #8 (permalink)
raselcox's Avatar
Member: 782943
Sonork: 100.1601067
Thanks Meter: 204
Model: SM-G530H
HWID: CQN00E757C28991
Imei: 357213********
Unlock Done.
Restarting phone.
Sucesfully unlock with Alpha battery trick
The Following User Says Thank You to raselcox For This Useful Post:
Old 12-01-2014, 12:52   #9 (permalink)
aaditigerhill's Avatar
Member: 1812419
Thanks Meter: 156
which box use for g530h unlock
Old 12-01-2014, 14:24   #10 (permalink)
Member: 128745
you need DTsamsung client credits and z3x box
Old 12-10-2014, 10:22   #11 (permalink)
Cheater -Don't Deal with him-
Member: 225400
Thanks Meter: 17
can i use dtsamsung client credits to samsung unlock direct usb cable . because i have no z3x box
Old 12-10-2014, 11:48   #12 (permalink)
Member: 2290533
Sonork: 100.1615863
Thanks Meter: 18
hi,
use octopus or spt for com port
Old 12-10-2014, 13:22   #13 (permalink)
Member: 128745
yes can use octopus . infinity . vygis , sptbox
Old 12-10-2014, 19:55   #14 (permalink)
Member: 225400
Thanks Meter: 17
i tell without any box possibale via usb cable
Old 12-15-2014, 17:33   #15 (permalink)
Member: 1870489
Sonork: 100.1663831
Thanks Meter: 483
SM-G530H unlock done
Model: SM-G530H
HWID: CQN00F607EE49A1
Imei: 35721306205828
Simlock status: 00000000
Unlock Done.
Restarting phone.
Page generated in 0.20815 seconds with 8 queries
