Unlock Sp motorola W200 Hello sir... how to unlock Motorola W200 Sp lock .. please help |
I think in this time not possible with infinity Motorola CDMA W150, W150i, W170, W170C, W200, W210, W355 . user/lock code read . flash read . flash write . esn repair http://www.infinity-box.com/ |
@zakiyyboss flash W200 with flash files from support area and see results. |
Dear sir, i flash the mobile as you did explain me.. but am still having insert uim card... when i insert a SIM CARD... please can you tell me if gsm sim card and ruim card are they the same? If no can we make the mobile accept normal simcard... I hope my question is not too stupid... |
@zakiyyboss to be honest your question not so smart (please, see that I did not write the word that you wrote by yourself). You can NOT use GSM phone sim card for CDMA phone ! But if you want to use W200 so much you can use ordinary SIM card in W200. Make this: 1. open W200 phone 2. remove CDMA PCB from W200 phone 3. install main PCB from GSM phone (f.e. from c115 or c139 or any other small phone) 4. be hapy man and use c115 or c139 with W200 case finally, it's good idea to read about CDMA and GSM. |
can any body help i got motorola w200 handset shows phonelocked please contact retailer so, plz any body help me about this i will be thank full to u |
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Moto-W150i_W200_W355_PHONE_LOCKED_CONTACT_SERVICE_CENTR E.txt |
Flash phone with w200_Flex_FFN_A66_1011_022 This means: 1. to get very important information about Infinity-Box read this C:\Program Files\InfinityBox\Documentation\Infinity-Box_UserManual.pdf 2. run software 3. select only "Flex" 4. use Flex file 5. flash phone Any luck with this method ? If you still can not understand what to do - tell me what is the problem and we will call you and we will explain you everything in details once again step by step. do not hesitate to contact us anytime |
Br Faisal_Computer |
thanks of the important information. but language problem, its in chinese language, any solution for it. |
Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355: Set English language: 1. Menu 2. Down 7 times, Right soft button 3. Down 3 times, Right soft button 4. Down 1 times, Right soft button 5. Down 4 times, Right soft button 6. select language now |
unlock Motorola W200 |
100000% solution here w200 PHONE_LOCKED_CONTACT_SERVICE_CENTR full flash with infintybox thxxxxxxxxxxxxxxx sir |
C:\InfinityBox\Documentation\Unlock_and_repair\Mot o\Moto-W200_PHONE_LOCKED_CONTACT_SERVICE_CENTRE.txt |
