10-12-2015, 20:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | unlock switel s4015d first in the world Code: Chinese Miracle II [MTK module] v 1.33 Operation : Check / Read Info [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 70010053313030303408286A011C6215 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 70010053313030303408286A011C6215 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Switel ProdName : S4015D ProdModel : S4015D MAGIC 2S Device : S4015D AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : SP Unlock [ v1.33 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 70010053313030303408286A011C6215 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 70010053313030303408286A011C6215 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM [1] codes : [1] Level , [Locked] : True , [Operator] : 5-01 [UnlockCode] : 11112222 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False SIM [2] codes : [1] Level , [Locked] : True , [Operator] : 5-01 [UnlockCode] : 11112222 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False ======== Info If phone not asking code : 1. Open MTK Setting Menu : *#*#3646633#*#* 2. GoTo : SimMELock->Network->Personalization->Unlock 3. Enter code If Code not accepted - use "SP Direct Unlock" mode Done! Elapsed: 00:00:27 and with direct unlock all ok Code: Operation : SP Unlock [ v1.33 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 70010053313030303408286A011C6215 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 70010053313030303408286A011C6215 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Locked! Unlocking ... Unlock done! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Last edited by nori2007; 10-12-2015 at 20:37. |
The Following User Says Thank You to nori2007 For This Useful Post: |
12-09-2015, 07:10 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | I got the same sets ,,,and wanna to unlock ,,,but i using latest version CM2 1.38 ,,,,which not given READ CODES in SP UNLOCK AREA,,,even sp unlock doesnot working ,,,,plz guide me HOW TO UNLOCK THESE SET ,,,,consisit on MT-6575,,,waiting .... |
12-09-2015, 08:17 | #5 (permalink) | |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Look here- http://forum.gsmhosting.com/vbb/f296.../#post11464399 Br. Infinity Box Support Team. | |
