10-18-2008, 08:05 | #1 (permalink) |
Freak Poster Join Date: May 1999
Member: 52 Status: Offline Thanks Meter: 13 | Unlock Toplux CG260 I have one which has the lock code and I try to use infinity pin finder, it detect the pin by indenpendent CPU and when I try to use other chinese to unlock it ca't be detected. Please help and give more advice, Thank you very much. Best Regards Ian |
10-21-2008, 07:10 | #3 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, The CPU name is Skyworks and come with serial number: CX80503-25 E399149-1 ARM and the the pin out is RX=11 TX=12. After I find the pin out, I don't know which program need to select, so I simply select Chinese miracale and select unknown cPU and wait it mention , press power on, once I press power on, phone started and can't be detect to unlock. Please advice me accordingly. Thank you very much. Best Regards Ian |
10-21-2008, 09:57 | #5 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, I still got no luck to read flash. The phone will power on once I press the power button and it can't be detected. The pin out conector is L24A cable. Is there any other model that I can try?? Please help.... Thank you very much.. |
10-21-2008, 15:48 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to read phone with other models from the same software module. All these models is for similar CPU chip type. |
10-22-2008, 06:34 | #8 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, After successfull read flash, When I press user code, it mention phone must be in testmode, I try power on or power of also cannot, it stated phone not found. I try to reset setting still got phone locked and don't know the dfault code. Please advice me please... Thank you very much |
10-22-2008, 15:11 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ NewGen_Fly_test-mode.txt What model exactly you have selected for flash reading ? Pls sent flash file backup and operation log to [email protected] |
10-23-2008, 02:54 | #10 (permalink) |
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, I am using Hyundai H350 model and from the document it stated press power on and if I press power on for more than 2 secound, the phone power up and if press one secound, it still stated no phone connected. Please advice me please... for the flash file already send Thank you very much. Best Regards Ian |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
toplux! AG280, Have keypad password! | minhtrimobile | Various | 2 | 12-17-2008 14:47 |
unlocking LG-cg225 | cellrepairus | NSPRO | 0 | 04-30-2008 22:37 |
Rare Toplux Cg260 For Sale | Devils Advecut | Sell ur Old and Used Stuff | 7 | 03-06-2004 13:42 |
Toplux CG260, new, barred in Sweden, unlocked. | Firecell | Sell ur Old and Used Stuff | 7 | 12-16-2003 01:07 |
