Unlock zte a68 done 100% HI selcet A66 then unlock COM8 [VCP2] selected module v1.58 Device: ZTE-A66 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: NGE-P108A5V1.0.0B02 ORANGE-P108A5B01-EnFr-MG02 g3dBV2.0 Apr 23 2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-static_20081229-173146.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-security_20081229-173147.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-complete_20081229-173153.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_lock-area_20081229-173200.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 39 sec Remove/Install battery now ! THANKS TO INFINITY TEAM |
Hello, Thanks a lot for your test report ! Please, read flash from A68 and send full flash backup to [email protected] Thanks in advance ! |
Whith new can't connect in infinitybox For checking, "ORANGE" in the front side (new) nothing ----------------(old) |
Hello, Do you have a PCB photo of so called "OLD" and "NEW" ? |
pcb of zte A68 old#A68 new Quote:
There are no difference PCB, but the new can't connect with INFINITY (ALL MODULE). I try all module like PANA01, HMODULE etc. It can connect with Furious but dead after unlock with VODAFONE MODULE. It can read eeprom and flash with VODAFONE & SAGEM MODULE (furious gold). Best regards. Josh |
lie, not possible Quote:
It can read, unlock ZTE A35, A68 old with PANA01 to choose ZTE A66. The result is like your result ok |
I think you must think twice before write words like lie ! Do you see operation log ? Do you see Pana01 module version ? I think you must say "sorry" right now to Mr. ismabdi Also about your words about your tries with Pana01 and HModule etc. I think you did not made any tries due to you did not posted any logs and no any PCB photo, so, please, if you want to write something in future think twice before post messages like "not wark" and "lie" without any reason. If you really tried something it's better to post real results instead of just a popular words like "not wark". |
zte a68 nor pinout???????? |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
hello infinity team pls help what cable can i use for a68 unlock for me can,t boot pls help thanx |
What is phone connector type ? |
thank's a lot 4 d' sharing,,,,,,,,,,,, you are the best.............. |
Please I can't unlock this model . I used A35 cable and folow the testpoint showing in the soft programme; but the phone connecting and write errer what can i do? |
