Old 12-29-2008, 16:13   #1 (permalink)
ismabdi's Avatar
Member: 461554
Thanks Meter: 55
Unlock zte a68 done 100%
HI
selcet A66 then unlock
COM8 [VCP2] selected
module v1.58
Device: ZTE-A66
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: NGE-P108A5V1.0.0B02 ORANGE-P108A5B01-EnFr-MG02 g3dBV2.0 Apr 23 2
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-static_20081229-173146.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-security_20081229-173147.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-complete_20081229-173153.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_lock-area_20081229-173200.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 39 sec
Remove/Install battery now !
THANKS TO INFINITY TEAM
The Following 4 Users Say Thank You to ismabdi For This Useful Post:
Old 12-29-2008, 16:20   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Hello,
Thanks a lot for your test report !
Please, read flash from A68 and send full flash backup to [email protected]
Thanks in advance !
Old 01-02-2009, 08:19   #3 (permalink)
Member: 169616
Thanks Meter: 19
Originally Posted by ismabdi View Post
HI
module v1.58
Device: ZTE-A66
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
this is a old security of ZTEA68
Whith new can't connect in infinitybox
For checking, "ORANGE" in the front side (new)
nothing ----------------(old)
The Following User Says Thank You to Roalnd78 For This Useful Post:
Old 01-02-2009, 21:41   #4 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Hello,
Do you have a PCB photo of so called "OLD" and "NEW" ?
Old 01-03-2009, 19:06   #5 (permalink)
josh_aina's Avatar
Member: 207280
Thanks Meter: 15
pcb of zte A68 old#A68 new
Originally Posted by InfinityN View Post
Hello,
Hi bro!
There are no difference PCB, but the new can't connect with INFINITY (ALL MODULE). I try all module like PANA01, HMODULE etc. It can connect with Furious but dead after unlock with VODAFONE MODULE. It can read eeprom and flash with VODAFONE & SAGEM MODULE (furious gold).
Best regards.
Josh
Old 01-03-2009, 19:11   #6 (permalink)
josh_aina's Avatar
Member: 207280
Thanks Meter: 15
lie, not possible
HI
module v1.58
Device: ZTE-A66
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Hi!
It can read, unlock ZTE A35, A68 old with PANA01 to choose ZTE A66. The result is like your result
ok
Old 01-03-2009, 20:20   #7 (permalink)
Member: 130995
Originally Posted by josh_aina View Post
Hi!
ok
Lie ?
I think you must think twice before write words like lie !
Do you see operation log ?
Do you see Pana01 module version ?
I think you must say "sorry" right now to Mr. ismabdi
Also about your words about your tries with Pana01 and HModule etc.
I think you did not made any tries due to you did not posted any logs and no any PCB photo, so, please, if you want to write something in future think twice before post messages like "not wark" and "lie" without any reason.
If you really tried something it's better to post real results instead of just a popular words like "not wark".
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-17-2009, 15:06   #8 (permalink)
Member: 52636
Thanks Meter: 5
zte a68 nor pinout????????
Old 01-17-2009, 17:44   #9 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 02-08-2009, 11:22   #10 (permalink)
Member: 767451
Thanks Meter: 178
hello infinity team pls help what cable can i use for a68 unlock for me can,t boot pls help thanx
Old 02-08-2009, 13:09   #11 (permalink)
Member: 130995
Hello,
What is phone connector type ?
Old 02-09-2009, 10:11   #12 (permalink)
Member: 798811
Sonork: astrong
Thanks Meter: 11
thank's a lot 4 d' sharing,,,,,,,,,,,, you are the best..............
Old 04-03-2009, 12:51   #13 (permalink)
Member: 385603
Please I can't unlock this model . I used A35 cable and folow the testpoint showing in the soft programme; but the phone connecting and write errer what can i do?
Unlock ZTE A933+ Done [GOOD WORK THX] WILUNLOCK PolarBox 3 14 10-23-2010 03:01
unlock zte f120 done... MauricioBC Infinity-Box 3 04-13-2009 11:38
ZTE A68 unlock done........ anz76 Infinity-Box 1 03-21-2009 18:30
ZTE A68?? Unlockable? zakiyyboss Infinity-Box 8 02-19-2009 17:24
unlock ZTE A68 with infinity matfrank5 Infinity-Box 4 12-18-2008 18:02
Page generated in 0.42630 seconds with 8 queries
