Old 02-11-2010, 12:50   #1 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
need n97 pinouts urgent
anyone help me plz i need china n97 pinouts
Old 02-14-2010, 08:46   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post connector type.
are you sure that this is mt62xx MCU based phone?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 02-14-2010, 17:23   #3 (permalink)
Member: 505446
Thanks Meter: 45
Guys please must not forget to give full details before sending request for any pin outs.
1-System connector type
2-full information from the imei labl
3-manufacturer name(eg mobicel,mobitel,LC,etc etc)
4-picture of the phone if possible
Old 02-21-2010, 22:23   #4 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
yes sir system connector is same like nokia original n97
Old 02-21-2010, 22:38   #5 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi..
is it 1x5 socket..?
pls check this..
Old 01-16-2011, 22:45   #6 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb operation n97 rm-505 read full flash, not work
COM8 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
boot packet size: 0400
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 17 sec
Remove/Install battery now !
__________________________________________________
on/off boot autoselect and not work again
cable 1x5 , how do? how read full flash???
__________________________________________________ ___
operation user/lock code
module v3.26
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6235
high speed boot On
status: FF
rom: 4D573031
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: ONECOM.09AW0932.W3598
Version: ONECOM_09A_HW
detecting structure #2...
1 4 5 8 9 11 12 done
90 byte(s) read
imei: 35422503001066
connection Ok
detecting structure #1...
0 1 7 8 9 12 14 15 16 18 19 25 26 27 30 32 33 34error: detection failed (18 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 18 sec
Old 01-17-2011, 21:01   #7 (permalink)
Member: 148515
hello!
please select correct CPU type "NAND"
Old 01-17-2011, 21:46   #8 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb its ok thanks
hello!
please any flash spanish lenguaje? how changue lenguaje?
Old 01-18-2011, 17:08   #9 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb flashing, nokia n97 china mobile rm-505
hi, i sucessfull flash for changue lenguaje spanish, this log:
module v3.26
Device: Autodetect 6228-6253 NAND
Action: write flash NAND
write: Firmware
CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598__firmware_20110117-171624.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_ONECOM_09AW 0932_W3598.bin
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: ONECOM.09AW0932.W3598
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: id-page1 area is invalid
nfi area detection (0 cores) finished: failed
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00020000
error: unexpected answer:
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 07
sw version: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN
project-id: ONECOM.09AW0932.W3598, 5B7CF5DB
code offset: 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._CELL ONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0932_ W3598.BIN_DBF57C5B_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01. ONECOM_09AW0932_W3598.BIN_DBF57C5B_.rpl
warning: unknown firmware: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B
Unknown firmware found (v.3.26, database date: 13.01.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 51 min 42 sec
DONE.... BUT PHONE NOT POWER ON, HOW DO?
Old 01-18-2011, 17:24   #10 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb Info firmaware
SORRY MULTIPOST.... I CANT EDIT MY POST
THIS IS INFO FIRMAWARE FOR FLASHING:
Loading file v.02...
CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598__firmware_20110117-171624.B4M.bin loaded
usb bootloader (file) is absent
rom info ver: 07
TCL-ID is absent
file w/protection: startup code area #1
firmware date/time: 2009-11-11 15-01
hw1: ONECOM_09A_HW
hw2: 09A_CELLONSZ35_09A
detecting languages...
Languages: En Ru Gr Fr Es Hu It Ro De Ml Id Th Vn Cn Farsi Pt Cn A
Old 01-19-2011, 00:28   #11 (permalink)
Member: 130995
Thanks Meter: 35,227
rom info ver: 07
TCL-ID is absent
hw1: ONECOM_09A_HW
Old 01-19-2011, 01:22   #12 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb flash good phone n97-rm-505
CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598__firmware_20110117-171624.B4M.rar - 4shared.com - online file sharing and storage - download
The Following User Says Thank You to thegran For This Useful Post:
need n82 pinout urgent tolski Infinity-Box 10 02-20-2009 04:25
Bluetooth N97 Pinouts needed zeerik Infinity-Box 3 12-22-2008 08:58
i need c168 pinouts urgent brain00000 Infinity-Box 1 10-19-2008 18:55
nokia 8800 pinout urgently need domestik Phoenix Black Box 5 06-29-2005 16:03
NEED sharp GX10 Pinouts... URGENT.. DrMobile Wanted Products 4 04-07-2003 07:14
Page generated in 0.24725 seconds with 10 queries
