08-11-2010, 10:31 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1059036 Status: Offline Thanks Meter: 57 | unlock ZTE SAGE problems COM6 [VCP0] selected module v3.53 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X670 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F003:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X671_V1_Z1_ES_DFFA105 Version: ZTEMT25_09A_GEMINI_HW 44 byte(s) read connection Ok 157 byte(s) read reading data... reading data #2... reading data #3... reading data #4... reading data #5... Unknown or damaged lock structure, what to do: 1. repeat operation and press and HOLD "Power" button more long time 2. use another unlock method, f.e. "unlock method: standard" 3. if nothing helps: read flash and send to support: [email protected] error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to GSM FREE For This Useful Post: |
08-11-2010, 11:55 | #2 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | i have flash phone bay zte x670 flash files and eprom phone work perfect bat always phone loked ( enter np code) i tested deferent unlock method bat solution not work OM6 [VCP0] selected module v3.53 Device: ZTE-X670 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F003:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.43E89 BFF.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rom info detection finished device-id: 43E89BFF rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... ................................................. lock area found ................................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC227E22632260:18E59F00000000 flash: EC227E22632260:18E59F00000000 Write: lock-area-1 flash: EC227E22632260:18E59F00000000 flash: EC227E22632260:18E59F00000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X670_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA111__system_log_43E89BFF_C07F45 09_20100811-104912.B0X.bin Finished, time used: 1 min 55 sec Remove/Install battery now ! COM6 [VCP0] selected module v3.53 Action: read unlock codes unlock method: read codes Model: ZTE-X670 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F003:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X670_V1_OG_Z2_FRES_DFFA111 Version: ZTEMT25_09A_GEMINI_HW 44 byte(s) read connection Ok 157 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 0 byte(s) read error: operation failed ! Finished, time used: 15 sec |
08-12-2010, 12:21 | #5 (permalink) |
Member: 1059036 Status: Offline Thanks Meter: 57 | phone is zte sage movistar spain image phone http://www.movilbroker.com/wp-conten...8/ZTE-sage.jpg flash file read by chinese softe zte sage.rar - 4shared.com - online file sharing and storage - download |
08-14-2010, 12:38 | #10 (permalink) | |
Try to use MModule v2.54 and unlock ZTE-X671, Sage. Waiting for your results. | |
09-28-2010, 10:34 | #14 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | ZTE Sage dead after unlock i've tried to flash wid the files on support and tried every thing. phone have white display and it blinks. here is the flash log. COM7 [VCP0] selected module v3.61 Device: ZTE-Sage Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:8203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.60CFD D31.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z 1_ES_DFFA105.BIN_24447341].rpl rom info detection finished device-id: 60CFDD31 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671_V1_Z 1_ES_DFFA105.BIN project-id: X671_V1_Z1_ES_DFFA105, 41734424 code offset: 00000000 ffs offset/size [02]: 01C00000/00400000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-Sage_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X671 _V1_Z1_ES_DFFA105__system_log_60CFDD31_24447341_20 100926-150209.B0X.bin Finished, time used: 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but phone is still white display and it blinks! plz help! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
