07-29-2009, 11:30 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420862 Status: Offline Thanks Meter: 51 | unlocked Alcatel S621 but keys malfunctioning today i tried to unlock S621 , handset was unlocked ok but there is a problem with its keypad is malfunctioning , like when we press 0 menu opens , for select option we have to press * key , to exit we have to use down key etc will i have to send the file to support which i have backed up before unlock ==== log: [7/29/2009 2:35:33 PM] ==== COM4 [Serial2] selected module v2.80 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S621X-2AALAP1-544_XD54BJ04_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2008-07-22_En_CnS_CnT_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:E203:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.97053 364.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_6D1C7C43].rpl ==================== New firmware detected (v.2.80, database date: unknown): JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 97053364 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, BC83E392 ffs offset/size: 01020000/00FE0000 ffs address assigned: 01020000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35608602xxxxxxx Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) calculation... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_97053364_6D1C7C43_20 090729-143610.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54BJ04 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_97053364_6D1C7C43_20 090729-150431.B0X.bin Finished, time used: 1735 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! thank u rockgsm |
07-29-2009, 18:21 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Yes you are right when you try to unlock Alcatel S261 you found problem like keypad , bluedisplay ....... If you have problrm flash higher versan 55X .... solve your problem Br. amar181 |
07-29-2009, 18:54 | #3 (permalink) | |
07-31-2009, 10:35 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to flash phone with other flash files from support area and see results. I think that one of files should work for your phone. In any case we will prepare your file and upload it in support area ASAP. |
07-31-2009, 16:02 | #6 (permalink) |
Member: 420862 Status: Offline Thanks Meter: 51 | Unlocked Alcatel S621 hi now my handset is working fine with no malfunction , i downloaded and flashed it with latest firmware , ==== log: [7/31/2009 3:38:36 PM] ==== COM7 [VCP2] selected module v2.80 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S621X-2AALBY1-556_XD55GA40_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-07_En_De_Ru_Bg_Ua_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:E203:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\INF\2009\MModule\backup_security\id.97053364.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_3439DEED].rpl identification#1 detection finished device-id: 97053364 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 1221C6CB ffs offset/size: 01020000/00FE0000 ffs address assigned: 01020000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35608602xxxxxxxx Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) calculation... security area (code #1) fixed file saved: C:\INF\2009\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_97053364_3439DEED_20 090731-153917.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD55GA40 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\INF\2009\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_97053364_3439DEED_20 090731-154254.B0X.bin Finished, time used: 256 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! regards rockgsm |
The Following User Says Thank You to rockgsm For This Useful Post: |
Sucsessfully unlock alcatel S621 !!! | reaz.com | Infinity-Box | 28 | 01-21-2010 00:48 |
pls help me how to unlock alcatel s621 | janki_amreli | Infinity-Box | 5 | 10-10-2009 14:15 |
Alcatel S621 dead by Unlock | Nasmi | Infinity-Box | 2 | 04-08-2009 14:16 |
alcatel s621 unlock | fraz12345 | Infinity-Box | 16 | 03-21-2009 17:59 |
alcatel s621 unlock flash need | G$M solution | Infinity-Box | 5 | 02-05-2009 16:05 |
