10-13-2005, 18:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | Help with Flashing a X70 writing error, after first read and remove and install battery. I am trying to use Winmodo by following the steps below to flash the phone -------------------------------------------------------------------------------- Now try to Flash it with Winmodo Step:-1 101% Fully Charged BATT. Step:-2 Backup of UPS (Very Very Important Stuff for this Field) 4. Start Winmodo 5. Menu Option -> Boot download: Checked 6. Menu Option -> Smart boot update: Checked 7. Menu Settings -> COM port: select COM port 8. Menu Settings -> Baud Rate: select 115200 9. "CUST" area: Red 10. "LP" area: Red 11. "CODE" area: Green 12. Press "Browse" button and select flash file 13. Connect cable to PC 14. Connect cable to phone 15. Press "Start Download" button 16. Shortly press phone power button if Menu Settings -> Baud Rate: select 115200 does not Workout then u can Reduce it... ---------------------------------------------------------- When the phone says signalling I press the power button, it says signalled recieved then Parameters Exchanged (with the Keypad light up) nothing else seems to be happening, i watch this for 10 minutes and no change..I try different baudrate and OS and still the same.. how long does Winmodo takes to flash a phone ? can anyone tell what may be the problem |
Help with flashing U708 and problem with locked files | buramario | Samsung Flashers, Software, Firmware. | 5 | 07-22-2009 10:08 |
please help with flash t230 gdfs with ufs3 | markLEE | Sony Ericsson | 2 | 09-27-2006 20:08 |
help with flashing e800 with ufs please | bawheid | UFS2 + UFS3-Tornadoflasher | 7 | 03-04-2006 14:27 |
Need help with flashing an a927 with chipset type 17 | freedomizer | Motorola P2k | 1 | 04-29-2005 08:18 |
