-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Unlok Banq Ef 51 Problem (http://forum.gsmhosting.com/vbb/f296/unlok-banq-ef-51-problem-414405/)
.::NabsGsm.:: 06-20-2007 15:00
Unlok Benq Ef 51 Problem
CAN YOU HELP ME PLZ I HAVE A PROBLEM To UNLOK BENQ EF 51
Device: BenQ EF51
Checking data, wait...
Action: Unlock
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Flash: 001C:00C8001C00C8
file saved: backup_eeprom-00_20070620-105221.91F.bin
Check Parameters Done
Check Space...
flash: Mitsubishi B 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Err: error flash vpp
Err: answer#00
try#1 to recover write error at 01710000
Err: answer#00
try#2 to recover write error at 01710000
Err: answer#00
try#3 to recover write error at 01710000
Err: answer#00
try#4 to recover write error at 01710000
Err: answer#00
try#5 to recover write error at 01710000
Err: answer#00
try#6 to recover write error at 01710000
Err: answer#00
try#1 to recover write error at 01712000
Err: answer#00
try#2 to recover write error at 01712000
Err: answer#00
try#3 to recover write error at 01712000
Err: answer#00
try#4 to recover write error at 01712000
Err: answer#00
try#5 to recover write error at 01712000
Err: answer#00
try#6 to recover write error at 01712000
Err: answer#00
try#1 to recover write error at 01714000
Err: answer#00
try#2 to recover write error at 01714000
Err: answer#00
try#3 to recover write error at 01714000
Err: answer#00
try#4 to recover write error at 01714000
Err: answer#00
try#5 to recover write error at 01714000
Err: answer#00
try#6 to recover write error at 01714000
Err: answer#00
try#1 to recover write error at 01716000
Err: answer#00
try#2 to recover write error at 01716000
Err: answer#00
try#3 to recover write error at 01716000
Err: answer#00
try#4 to recover write error at 01716000
Err: answer#00
try#5 to recover write error at 01716000
Err: answer#00
try#6 to recover write error at 01716000
Err: answer#00
try#1 to recover write error at 01718000
Err: answer#00
try#2 to recover write error at 01718000
Err: answer#00
try#3 to recover write error at 01718000
Err: answer#00
try#4 to recover write error at 01718000
Err: answer#00
try#5 to recover write error at 01718000
Err: answer#00
try#6 to recover write error at 01718000
Err: answer#00
try#1 to recover write error at 0171A000
Err: answer#00
try#2 to recover write error at 0171A000
Err: answer#00
try#3 to recover write error at 0171A000
Err: answer#00
try#4 to recover write error at 0171A000
Err: answer#00
try#5 to recover write error at 0171A000
Err: answer#00
try#6 to recover write error at 0171A000
Err: answer#00
try#1 to recover write error at 0171C000
Err: answer#00
try#2 to recover write error at 0171C000
Err: answer#00
try#3 to recover write error at 0171C000
Err: answer#00
try#4 to recover write error at 0171C000
Err: answer#00
try#5 to recover write error at 0171C000
Err: answer#00
try#6 to recover write error at 0171C000
Err: answer#00
try#1 to recover write error at 0171E000
Err: answer#00
try#2 to recover write error at 0171E000
Err: answer#00
try#3 to recover write error at 0171E000
Err: answer#00
try#4 to recover write error at 0171E000
Err: answer#00
try#5 to recover write error at 0171E000
Err: answer#00
try#6 to recover write error at 0171E000
Writing Fail
Finished, time used: 481 sec
Remove/Install battery now !
.::NabsGsm.:: 06-21-2007 23:51
plz infinity support i have many pieces to unlock any help plz i have read the full flash.bin and eprom if you wont i can send it to support :( ;)
InfinitySupport 06-23-2007 00:11
Hello,
I understand the problem and will try to fix it, but can't promise anythig for sure right now.
It's no need to send me flash/eeprom, I have got several files already.
nabs_gsm 06-23-2007 12:20
ok thanks good work
spider-man 08-05-2007 20:55
ef51 brand not work ..remove it in programme or fix the bugs:mad:
BouRRi_GSM 08-05-2007 21:03
still no solution for Ef51 with infinity, only work with 1 or 2 provider
Falck 09-19-2007 10:35
Have exactly same problem here with EF51, its long time ago this problem was posted 1st time, please fix it ;)
WBR Falck
LordMen007 10-11-2007 13:38
long time ago & still not fixed ,wats going on Infinity team
COM3 selected
Device: BenQ EF51
Action: Unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
file saved: backup_eeprom-00_20071011-113631.91F.bin
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Err: answer#00
try#1 to recover write error at 016E0000
Err: answer#00
try#2 to recover write error at 016E0000
Err: answer#00
try#3 to recover write error at 016E0000
Err: answer#00
try#4 to recover write error at 016E0000
Err: answer#00
try#5 to recover write error at 016E0000
Err: answer#00
try#6 to recover write error at 016E0000
Err: answer#00
try#1 to recover write error at 016E2000
Err: answer#00
try#2 to recover write error at 016E2000
Err: answer#00
try#3 to recover write error at 016E2000
Err: answer#00
try#4 to recover write error at 016E2000
Err: answer#00
try#5 to recover write error at 016E2000
Err: answer#00
try#6 to recover write error at 016E2000
Err: answer#00
try#1 to recover write error at 016E4000
Err: answer#00
try#2 to recover write error at 016E4000
Err: answer#00
try#3 to recover write error at 016E4000
Err: answer#00
try#4 to recover write error at 016E4000
Err: answer#00
try#5 to recover write error at 016E4000
Err: answer#00
try#6 to recover write error at 016E4000
Writing Fail
LordMen007
virgix 10-24-2007 19:34
can infinity sp unlock this model???
when update come???
thanx...
realmadrid 12-07-2007 18:51
we are waiting for a long time infinity team please fix this bugs we need to unlock ef51
b.r
don omar
InfinityHelp 12-07-2007 23:09
hello!
we remmember about this problem, working to solve it
notgood 12-08-2007 10:50
Originally Posted by InfinityHelp (Post 2929298)
hello!
i already try this model with infinity .. it's can't unlock, reset seting, n phonelock/usercode..... please infinityteam solve this problem, THX
br
notgood
freeman2001 03-20-2008 15:30
Oi
the sam problem after many mant's ago
COM3 [VCP0] selected
Device: BenQ EF51
Action: unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20080319-141205.91F.bin
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
error: error flash vpp
try#1 to recover write error at 01610000
error: flash end
try#2 to recover write error at 01610000
error: answer#EE
try#3 to recover write error at 01610000
error: answer#66
try#4 to recover write error at 01610000
error: answer#13
try#5 to recover write error at 01610000
error: answer#E0
try#6 to recover write error at 01610000
error: answer#00
try#1 to recover write error at 01612000
error: answer#00
try#2 to recover write error at 01612000
error: answer#E0
try#3 to recover write error at 01612000
error: answer#00
try#4 to recover write error at 01612000
error: answer#00
try#5 to recover write error at 01612000
error: answer#E0
try#6 to recover write error at 01612000
error: answer#00
try#1 to recover write error at 01614000
error: answer#00
try#2 to recover write error at 01614000
error: answer#00
try#3 to recover write error at 01614000
error: answer#FF
try#4 to recover write error at 01614000
error: answer#FF
try#5 to recover write error at 01614000
error: answer#07
try#6 to recover write error at 01614000
error: answer#00
try#1 to recover write error at 01616000
error: answer#FD
try#2 to recover write error at 01616000
error: answer#FF
try#3 to recover write error at 01616000
error: answer#00
try#4 to recover write error at 01616000
error: answer#00
try#5 to recover write error at 01616000
error: answer#FF
try#6 to recover write error at 01616000
error: answer#1F
try#1 to recover write error at 01618000
error: answer#00
try#2 to recover write error at 01618000
error: answer#1F
try#3 to recover write error at 01618000
error: answer#00
try#4 to recover write error at 01618000
error: answer#00
try#5 to recover write error at 01618000
error: answer#FF
try#6 to recover write error at 01618000
error: answer#0F
try#1 to recover write error at 0161A000
error: answer#00
try#2 to recover write error at 0161A000
error: answer#FF
try#3 to recover write error at 0161A000
error: answer#02
try#4 to recover write error at 0161A000
error: answer#00
try#5 to recover write error at 0161A000
error: answer#FF
try#6 to recover write error at 0161A000
error: answer#02
try#1 to recover write error at 0161C000
error: answer#00
try#2 to recover write error at 0161C000
error: answer#7F
try#3 to recover write error at 0161C000
error: answer#00
try#4 to recover write error at 0161C000
error: answer#00
try#5 to recover write error at 0161C000
error: answer#FF
try#6 to recover write error at 0161C000
error: answer#00
try#1 to recover write error at 0161E000
error: answer#00
try#2 to recover write error at 0161E000
error: answer#FF
try#3 to recover write error at 0161E000
error: answer#00
try#4 to recover write error at 0161E000
error: answer#00
try#5 to recover write error at 0161E000
error: answer#7F
try#6 to recover write error at 0161E000
Writing Fail
Finished, time used: 101 sec
boujemaa3 05-20-2011 20:40
yahia ali 08-18-2011 12:43
i have the same problem i wait mor then 2 years but stil no solution,plz infinity team fix this bug
Page generated in 0.31946 seconds with 5 queries
