Old 06-20-2007, 14:00   #1 (permalink)
.::NabsGsm.::'s Avatar
Member: 152849
Thanks Meter: 2
Unlok Benq Ef 51 Problem
CAN YOU HELP ME PLZ I HAVE A PROBLEM To UNLOK BENQ EF 51
Device: BenQ EF51
Checking data, wait...
Action: Unlock
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Flash: 001C:00C8001C00C8
file saved: backup_eeprom-00_20070620-105221.91F.bin
Check Parameters Done
Check Space...
flash: Mitsubishi B 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Err: error flash vpp
Err: answer#00
try#1 to recover write error at 01710000
Err: answer#00
try#2 to recover write error at 01710000
Err: answer#00
try#3 to recover write error at 01710000
Err: answer#00
try#4 to recover write error at 01710000
Err: answer#00
try#5 to recover write error at 01710000
Err: answer#00
try#6 to recover write error at 01710000
Err: answer#00
try#1 to recover write error at 01712000
Err: answer#00
try#2 to recover write error at 01712000
Err: answer#00
try#3 to recover write error at 01712000
Err: answer#00
try#4 to recover write error at 01712000
Err: answer#00
try#5 to recover write error at 01712000
Err: answer#00
try#6 to recover write error at 01712000
Err: answer#00
try#1 to recover write error at 01714000
Err: answer#00
try#2 to recover write error at 01714000
Err: answer#00
try#3 to recover write error at 01714000
Err: answer#00
try#4 to recover write error at 01714000
Err: answer#00
try#5 to recover write error at 01714000
Err: answer#00
try#6 to recover write error at 01714000
Err: answer#00
try#1 to recover write error at 01716000
Err: answer#00
try#2 to recover write error at 01716000
Err: answer#00
try#3 to recover write error at 01716000
Err: answer#00
try#4 to recover write error at 01716000
Err: answer#00
try#5 to recover write error at 01716000
Err: answer#00
try#6 to recover write error at 01716000
Err: answer#00
try#1 to recover write error at 01718000
Err: answer#00
try#2 to recover write error at 01718000
Err: answer#00
try#3 to recover write error at 01718000
Err: answer#00
try#4 to recover write error at 01718000
Err: answer#00
try#5 to recover write error at 01718000
Err: answer#00
try#6 to recover write error at 01718000
Err: answer#00
try#1 to recover write error at 0171A000
Err: answer#00
try#2 to recover write error at 0171A000
Err: answer#00
try#3 to recover write error at 0171A000
Err: answer#00
try#4 to recover write error at 0171A000
Err: answer#00
try#5 to recover write error at 0171A000
Err: answer#00
try#6 to recover write error at 0171A000
Err: answer#00
try#1 to recover write error at 0171C000
Err: answer#00
try#2 to recover write error at 0171C000
Err: answer#00
try#3 to recover write error at 0171C000
Err: answer#00
try#4 to recover write error at 0171C000
Err: answer#00
try#5 to recover write error at 0171C000
Err: answer#00
try#6 to recover write error at 0171C000
Err: answer#00
try#1 to recover write error at 0171E000
Err: answer#00
try#2 to recover write error at 0171E000
Err: answer#00
try#3 to recover write error at 0171E000
Err: answer#00
try#4 to recover write error at 0171E000
Err: answer#00
try#5 to recover write error at 0171E000
Err: answer#00
try#6 to recover write error at 0171E000
Writing Fail
Finished, time used: 481 sec
Remove/Install battery now !
Old 06-21-2007, 22:51   #2 (permalink)
Member: 152849
Thanks Meter: 2
plz infinity support i have many pieces to unlock any help plz i have read the full flash.bin and eprom if you wont i can send it to support
Old 06-22-2007, 23:11   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
I understand the problem and will try to fix it, but can't promise anythig for sure right now.
It's no need to send me flash/eeprom, I have got several files already.
Old 06-23-2007, 11:20   #4 (permalink)
Member: 481576
ok thanks good work
Old 08-05-2007, 19:55   #5 (permalink)
spider-man's Avatar
Member: 135039
Thanks Meter: 1,486
ef51 brand not work ..remove it in programme or fix the bugs
Old 08-05-2007, 20:03   #6 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
still no solution for Ef51 with infinity, only work with 1 or 2 provider
Old 09-19-2007, 09:35   #7 (permalink)
Falck's Avatar
Member: 18805
Thanks Meter: 27
Have exactly same problem here with EF51, its long time ago this problem was posted 1st time, please fix it
WBR Falck
Old 10-11-2007, 12:38   #8 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
long time ago & still not fixed ,wats going on Infinity team
COM3 selected
Device: BenQ EF51
Action: Unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
812500
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
file saved: backup_eeprom-00_20071011-113631.91F.bin
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Err: answer#00
try#1 to recover write error at 016E0000
Err: answer#00
try#2 to recover write error at 016E0000
Err: answer#00
try#3 to recover write error at 016E0000
Err: answer#00
try#4 to recover write error at 016E0000
Err: answer#00
try#5 to recover write error at 016E0000
Err: answer#00
try#6 to recover write error at 016E0000
Err: answer#00
try#1 to recover write error at 016E2000
Err: answer#00
try#2 to recover write error at 016E2000
Err: answer#00
try#3 to recover write error at 016E2000
Err: answer#00
try#4 to recover write error at 016E2000
Err: answer#00
try#5 to recover write error at 016E2000
Err: answer#00
try#6 to recover write error at 016E2000
Err: answer#00
try#1 to recover write error at 016E4000
Err: answer#00
try#2 to recover write error at 016E4000
Err: answer#00
try#3 to recover write error at 016E4000
Err: answer#00
try#4 to recover write error at 016E4000
Err: answer#00
try#5 to recover write error at 016E4000
Err: answer#00
try#6 to recover write error at 016E4000
Writing Fail
LordMen007
Old 10-24-2007, 18:34   #9 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
can infinity sp unlock this model???
when update come???
thanx...
Old 12-07-2007, 18:51   #10 (permalink)
realmadrid's Avatar
Member: 201648
Thanks Meter: 19
we are waiting for a long time infinity team please fix this bugs we need to unlock ef51
b.r
don omar
Old 12-07-2007, 23:09   #11 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we remmember about this problem, working to solve it
Old 12-08-2007, 10:50   #12 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
hello!
i already try this model with infinity .. it's can't unlock, reset seting, n phonelock/usercode..... please infinityteam solve this problem, THX
br
notgood
Old 03-20-2008, 14:30   #13 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Oi
the sam problem after many mant's ago
COM3 [VCP0] selected
Device: BenQ EF51
Action: unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20080319-141205.91F.bin
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
error: error flash vpp
try#1 to recover write error at 01610000
error: flash end
try#2 to recover write error at 01610000
error: answer#EE
try#3 to recover write error at 01610000
error: answer#66
try#4 to recover write error at 01610000
error: answer#13
try#5 to recover write error at 01610000
error: answer#E0
try#6 to recover write error at 01610000
error: answer#00
try#1 to recover write error at 01612000
error: answer#00
try#2 to recover write error at 01612000
error: answer#E0
try#3 to recover write error at 01612000
error: answer#00
try#4 to recover write error at 01612000
error: answer#00
try#5 to recover write error at 01612000
error: answer#E0
try#6 to recover write error at 01612000
error: answer#00
try#1 to recover write error at 01614000
error: answer#00
try#2 to recover write error at 01614000
error: answer#00
try#3 to recover write error at 01614000
error: answer#FF
try#4 to recover write error at 01614000
error: answer#FF
try#5 to recover write error at 01614000
error: answer#07
try#6 to recover write error at 01614000
error: answer#00
try#1 to recover write error at 01616000
error: answer#FD
try#2 to recover write error at 01616000
error: answer#FF
try#3 to recover write error at 01616000
error: answer#00
try#4 to recover write error at 01616000
error: answer#00
try#5 to recover write error at 01616000
error: answer#FF
try#6 to recover write error at 01616000
error: answer#1F
try#1 to recover write error at 01618000
error: answer#00
try#2 to recover write error at 01618000
error: answer#1F
try#3 to recover write error at 01618000
error: answer#00
try#4 to recover write error at 01618000
error: answer#00
try#5 to recover write error at 01618000
error: answer#FF
try#6 to recover write error at 01618000
error: answer#0F
try#1 to recover write error at 0161A000
error: answer#00
try#2 to recover write error at 0161A000
error: answer#FF
try#3 to recover write error at 0161A000
error: answer#02
try#4 to recover write error at 0161A000
error: answer#00
try#5 to recover write error at 0161A000
error: answer#FF
try#6 to recover write error at 0161A000
error: answer#02
try#1 to recover write error at 0161C000
error: answer#00
try#2 to recover write error at 0161C000
error: answer#7F
try#3 to recover write error at 0161C000
error: answer#00
try#4 to recover write error at 0161C000
error: answer#00
try#5 to recover write error at 0161C000
error: answer#FF
try#6 to recover write error at 0161C000
error: answer#00
try#1 to recover write error at 0161E000
error: answer#00
try#2 to recover write error at 0161E000
error: answer#FF
try#3 to recover write error at 0161E000
error: answer#00
try#4 to recover write error at 0161E000
error: answer#00
try#5 to recover write error at 0161E000
error: answer#7F
try#6 to recover write error at 0161E000
Writing Fail
Finished, time used: 101 sec
Old 05-20-2011, 19:40   #14 (permalink)
Member: 559971
Old 08-18-2011, 11:43   #15 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 169
i have the same problem i wait mor then 2 years but stil no solution,plz infinity team fix this bug
infinity can't unlock EF 51??????????, mscomp Infinity-Box 1 10-21-2009 10:29
Unlok Banq Ef 51 Problem .::NabsGsm.:: TSMbox+ 3 12-08-2007 17:09
Ef 51 domidelcourt Infinity-Box 1 11-11-2007 14:54
unlock EF 51 snipergsm Infinity-Box 3 04-13-2007 18:05
Page generated in 0.28328 seconds with 9 queries
