07-03-2006, 11:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | unsupported C168 version Device: C168 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1420-000 HW ver: TCT-9- Check Flash Done Check Parameters... Err: this version is not supported yet. read flash and send to support Check Parameters Fail Finished Remove/Install battery now ! Time used: 12 sec Make "SP-Unlock" operation now ! Should i flash this phone first with another version or wait for update????? |
07-03-2006, 22:30 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, it was not so good idea to flash phone because version that was in your phone mewer that we have in support. Please, if you will see phone with this version (1420) in future read flash and send to [email protected] and we will make update fast. As about blocked "network pin". pls, send me all backup files that was auto-created after unlock: [email protected] Also it can be that it's need to power on phone and wait some time untill it will be possible to enter network pin. |
07-04-2006, 09:11 | #4 (permalink) |
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | my problem solved by flashing fone with firmware present in support....and yes after 2 hours "network pin blocked" message gone....and i unlocked fone by codes easily.... i have mailed the backup file on that address |
07-04-2006, 14:15 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Glad to hear about good results. Thanks for backup file. Update for this software version will be uploaded in support area today in some time. |
10-09-2006, 15:40 | #7 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | i mail you support team "[email protected]" I try all version but still same problem "Network Pin Blocked" pleses solve my problem. |
10-09-2006, 16:28 | #8 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
and yes after 2 hours "network pin blocked" message gone....and i unlocked fone by codes easily | |
01-25-2009, 03:13 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
02-02-2009, 14:42 | #14 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
Alcatel OT-C635 Unsupported firmware version! | bachgoro | Easy-Unlocker | 3 | 10-04-2007 10:05 |
alcatel c630 Unsupported fw version | alex1205 | FuriousGold | 10 | 07-23-2007 15:08 |
Unlocking Unsupported RAP3G versions | kushstha | Nokia Base Band 5 ( BB-5 ) | 7 | 06-22-2007 22:33 |
Unsupported fw version | founounfounoun | FuriousGold | 7 | 05-28-2007 19:04 |
Unsupported fw version | youssef-nokia | FuriousGold | 2 | 02-27-2007 18:32 |
