Old 09-10-2015, 12:25   #1 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,728
unsupported or erased flash
Card found: S/N
Chinese Miracle II [MTK module] v 1.29
Operation : Reset Privacy Lock [ v1.29 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 002C00BC009000660054000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0088 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Error read initial info , unsupported or erased flash
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 09-10-2015, 12:31   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,635
Hello.
MTK : Last step for Full NAND support :)
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-10-2015, 13:03   #3 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,728
not solve sir.
Card found: S/N
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Checking data ...
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Checking data ...
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Checking data ...
Done!
Elapsed: 00:00:12
Operation : Check / Read Info [ v1.29 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Phone found! [ 13 ]
Sync...
Got PMT Data!
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:28
Operation : Format FileSystem [ v1.29 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:10
Old 09-10-2015, 13:07   #4 (permalink)
p.k510's Avatar
Member: 1778370
Sonork: sujan_goa
Thanks Meter: 66
please add 6571/6572 nand mtk andrid cpu full flesh format read repair unkhounw besbend
The Following User Says Thank You to p.k510 For This Useful Post:
Page generated in 0.20254 seconds with 7 queries
