10-09-2018, 14:28 | #1201 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Flashing - partitions list updated to support newest models/devices for flashing Intrface bugs fixed Included new procedure to support new FRP Reset method (in test, comming soon) https://www.infinity-box.com/news/?r=1258 |
The Following 6 Users Say Thank You to YellowBoss For This Useful Post: |
11-06-2018, 08:07 | #1202 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity `SM` software v2.04 released Flasing - add Reset userlock / pin / pattern / password in FRP ON + OEM ON mode options Many bug fixed How to use Reset User lock options: - see phone version in Recovery menu - download COMBINATION file according to the phone version - check checkbox and add your COMBINATION file - flash phone - after write COMBINATION file wait phone is turned on - phone on in recovery mode, reboot phone - you have access to phone data after backup user data - reflash phone https://www.infinity-box.com/support/?r=100050 |
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post: |
11-07-2018, 00:23 | #1203 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features Important: - Software installed to new folder /CM2MT2/ and designed to support new models Legacy core support activated: MT6571 MT6572 MT6580 MT6582 MT6589 MT6592 MT6595 MT6597 MT6732 MT6735 MT6737 MT6752 MT6753 MT6795 MT8127 MT8163 MT8321 MT8732 MT8735 MT8752 Identify: full device info, security info Flash Factory Firmware Read Factory Firmware Reset Settings / Format FS Reset FRP Repair Security (Flash Mode, Direct) SP unlock MemoryTool - complete device control, service, repair, forensic etc. - Main Loader database optimized, size reduced. DA v1820 line support tested and activated DA v1836 line support tested and activated Connection level revised BROM level support optimized Optimized and changed HighSpeed port selection FlashEngine revised NVRAM tool revised Global option PWM - allow switch SW between two different work modes for RAPHAEL. > Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc. > For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE ) - Service Repair Security revised > Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes ! Format FS - new mode activated: Forced Erase Format FS - fixed WIPE mode - Core EMIDB updated New EMI engine for LEGACY line > EMI engine support almost all existing LEGACY line > New types for RAPHAEL included - FW reader LEGACY core supported ( unsigned and static signed types are supported ) New types of firmwares supported Scatter creation optimized - Other Settings tab activated ( firmware path settings and other features can be found here ) AutoUpdate ( module files ) feature activated Many other changes and fixes Known issues/warnings/info: 1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list. 2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list ! 3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed. 4. MT6592 support on DAv18xx loader line broken ( DA issue ) 5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP ) 6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC ) 7. NAND support on LEGACY line is not activated yet https://www.infinity-box.com/support/?r=100051 |
The Following 5 Users Say Thank You to InfinityHelp For This Useful Post: |
11-12-2018, 06:33 | #1204 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.02 - new features, loaders, improvements - Base Base - Read info from EMI base (preloader) in manual mode after selection Base - Info reading improved ( in some cases device info can be empty ) Base - Manual mode selection revised ( Boot fail issues in manual mode ) - MemoryTool MemTool - Partition types detection improved MemTool - Interface changes ( partition selection style changed, menu sctructure changed ) MemTool - work with boot1/boot2 section revised for LEGACY line MemTool - InitPreloader option activated ( LEGACY/RAPHAEL ) MemTool - Flash service regions read/write now allowed ( if they not set as protected - i.e. OTP ) - Flasher Flasher - Removed "Skip preloader" option, use selection instead ( untick preloader from flashing list ) Flasher - Customization model revised Flasher - DL Fix / ADL Checksum revised Flasher - Preloader initialization during flashing revised Flasher - More accurate PMT/GPT rebuild, for compatibility with SPFT ( PMT invalid issues after servicing with MT2 module ) - Firmware Reader FWReader - Scatter compatibility for spft optimized (6735, 6737) FWReader - More types supported for safe read FWReader - Info reading improved ( in some cases device info can be empty ) FWReader - SW path settings also accepted now on FW read - Platform changes Platform - MT6589 support optimized Platform - MT6592 support optimized Platform - MT673x support optimized - Loader database LoaderDB - New agents included ( BQ, TECNO, INFINIX, VIVO ) - Other Other - Lot of small fixes and changes, reported by users Thanks to : gracy_elec, kamal_singla and other our users for providing files and/or testing https://www.infinity-box.com/support/?r=100052 |
11-21-2018, 10:36 | #1205 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features - Forensic engine for MTK feature line devices rebuild from scratch Allow extract phonebook memory from alive/dead/semi-dead devices From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions ) > Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode Extraction is direct (from device) and from dump Support unicode All existing MTK FP models are supported now for PhoneBook extraction: Nokia 108: RM-944, RM-945, RM-1124 Nokia 220: RM-969, RM-970, RM-971, RM-1125 Nokia 225: RM-1011, RM-1012, RM-1043 Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122 Nokia 215: RM-1110, RM-1111, RM-1112 Nokia 105: RM-1133, RM-1134, RM-1135 Nokia 222: RM-1136, RM-1137 Nokia 230: RM-1172, RM-1173 Nokia 216: RM-1187, RM-1188 Nokia 150: RM-1189, RM-1190 Nokia 3310(2G): TA-1008, TA-1030 Nokia 105(2017) : TA-1010, TA-1034, TA-1037 Nokia 130(2017) : TA-1017, TA-1019 - Changes/Fixes > MTK FP line Fix/Change: Flash engine revised New feature: SW version check during flashing activated. SW will verify data between phone and VPL. > In case of device dead ( no SW version data available ) - SW will warn about it. New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify ) > MTK SP line Fix/Change : Flash engine revised Fix/Change : Repartition may fail during NK1 flashing, fixed Read more here |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
12-06-2018, 09:27 | #1206 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Samsung `SM` v2.05 released Service: added new version of Reset FRP procedure (without user-data lost) How to use: check "new" checkbox and follow instructions https://www.infinity-box.com/support/?r=100058 |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
01-25-2019, 14:38 | #1207 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Samsung `SM` v2.06 released Flashing: added support for lz4 partitions flashing System: AutoReadInfo procedure removed to make connection more stable and faster Minor bugs fixed https://www.infinity-box.com/support/?r=100060 |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
01-29-2019, 11:23 | #1208 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.04 - New chips support and new features activated Base: Base - MT6761 support activated Base - MT6765 support activated Base - MT6771 support activated Base - Secure boot - ARB verification during boot ( via BROM logging ) Base - Secure boot - SLA challenge state verify ( pass-trought file or nonce challenge ) FWFlasher: FWFlasher - Some ancient secure devices flashing optimized ( early 6572 and similar ) FWFlasher - MT6753/MT6752 flashing revized FWFlasher - Pre-flash backup option enabled FWFlasher - Flash core updated FWReader: FWReader - More accurate FW verification for signed types ( issues after FOTA "garbaging" ) FWReader - ARB state and version, if present ARB bit FWReader - AVB state and version, if present AVB secure mechanism FWReader - FW logging info - if SW show it during load - make sure device contain SAME or LOWER version! FWReader - More types supported for safe read FWReader - Info reading improved Service: Service - Security repair revised ( NVRAM verify and some "old" types support ) Service - "Repair BaseBand" option activated Service - Format FS revised Service - NVRAM module updated MemoryTool: MemTool - Improved work with partitions on LEGACY line MemTool - Wipe operation optimized ( def and adr mode ) Platform: Platform - MT6761 support activated [ Under test ] Platform - MT6771 support activated Platform - MT6765 support activated Platform - MT6753 support optimized Platform - MT8172 support optimized Platform - MT8176 support optimized Platform - MT8163 support optimized Platform - MT8127 support optimized Loaders: LoaderDB - New agents included ( Moto, Huawei, ZTE, Asus and others ) Other: Other - Lot of different small changes and fixes Other - BootHelper updated Other - ErrorHandling updated - more detailed hints/explanation of troubles during service process Other - EMI Module updated - MT6765/MT6771/MT8176/MT8172/MT8173/MT6753 supported Other - Automatic backup during Identify and critical operations ( list can be tuned via edit settings.ini ) Other - Partial LEGACY NAND support ( complete boot/verify ) for testing purposes for now - MT6580, MT81xx series Other - All settings ( except FLASH tab and Platform Settings group ) now saved/load automatically https://www.infinity-box.com/support/?r=100061 |
02-16-2019, 12:32 | #1209 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 MTK/Mediatek v2.05 - New models and features Base: Base - Secure boot - ARB verification revised for some secure configs and chips FWFlasher: FWFlasher - Flash core updated FWFlasher - SecureFlash on Legacy phones revised ( SECCFG options and other issues fixed ) FWFlasher - MT6753/MT6752 flashing revised FWReader: FWReader - More accurate type detection on LEGACY lines FWReader - More types supported for safe read FWReader - Info reading improved Service: Service - "SimLock Reset" option activated - used to rollback all LockSettings to default Service - Format FS revised Service - Repair BB revised Service - NVRAM module updated Platform: Platform - MT6771 support optimized Platform - MT6753 support optimized Platform - MT8127 support optimized Loaders: LoaderDB - Lot of new agents included (Alcatel, Moto, Lava and others) Other: Other - Many different small changes and fixes Other - Some kind of GUI changes for better user expirience Other - ErrorHandling updated - more detailed hints/explanation of troubles during service process Other - EMI Module updated Other - Preloader tools, Preloader init and other related stuff updated Other - Scatter handling optimized for some vendor-specific stuff Other - Automatic backup revised (manual tuneup fix) Other - Partial LEGACY NAND support (complete boot/verify) - Identify option works now on some devices Info: Info: Alcatel support for NEW line devices restricted by PRELOADER level ONLY! Some partitions are PROTECTED! BROM mode not supported for now ( due remote SLA ) Info: LEGACY secure flashing now pass at any base settings but IN SOME RARE CASES (like Huawei and similar) it may lead to BaseBand and other problems. Solution - REFLASH using CORRECT DA! Info: ARB nowdays appearing on more devices, make sure about you FLASH SAME version. (Identify ARB LOG and SW load LOG ) Not upgrade to newer ones, if need make some extend service etc. ! https://www.infinity-box.com/support/?r=100062 |
02-20-2019, 21:00 | #1210 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle II SCR/SPD-RDA v1.04: New models and features Supported CPU list: Spreadtrum : SC6530, SC6531, SC6531(A/C/D) UniSoc : SC6531E, SC6533, SC6533G RDA Mirco : RDA8851 rev A,B,C,L,CL RDA Micro : RDA8826 RDA Mirco RDA8851 rev A,B,C,L,CL RDA Micro RDA8826 Spreadtrum SC6533/G : Flashing protocol updated BOOTROM mode support revised Updated LOD tools ( flashing / customizing ) Repair security revised ( -> FAC area rebuild -> 3rd item repair activated UserCode reading activated Spreadtrum SC6530/6531/A/C/D/E: Revised Repair security feature Flashing revised -> Secure/Signed lines flashing rebuild -> Masterimage build revised -> Whole flash erase fixed for NOR devices Internal loaders updated Database revised, loaders re-marked Spreadtrum other: Protocol updated, stuck issues during wrong boot selection fixed Improved Flashing procedure for SC7701/SC7702 devices Flashing customization module revised InternalDB/ExternalLoader detetection/selection revised https://www.infinity-box.com/support/?r=100064 |
03-17-2019, 22:28 | #1211 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity-Box [BEST] NK2 v1.10 - Nokia 3310 3G support and new features - Nokia SPRD tab activated Nokia 3G SS [TA-1006] supported Nokia 3G SS [TA-1022] supported Nokia 3G DS [TA-1036] supported - Identify - Reset Settings / Format FS - Firmware Flashing ( cross, nvm update, lang change ) Info: Device security paired, store all NV backups to emergency case ! Info: Crossflashing can be done and not touch security ( require enable NV update ) - Nokia SP tab changes Identify now read BOTH part info for A/B devices Flash Engine updated "UserData preserve" mode updated Format FS / Reset FRP revised Nokia 5.1+ ( Nokia X5 ) supported ( TA-1102, TA-1105, TA-1108, TA-1109, TA-1112, TA-1120 ) Nokia 3.1+ supported ( TA-1104, TA-1113, TA-1115, TA-1117, TA-1118, TA-1125 ) - Identify - Reset Settings / Format FS / Reset FRP - Firmware Flashing - Nokia FP tab changes PhoneBook extraction engine updated Extract "from file" revised Flash Engine updated https://www.infinity-box.com/support/?r=100065 |
The Following 4 Users Say Thank You to InfinityHelp For This Useful Post: |
03-25-2019, 06:57 | #1212 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.11 - More MTK and SPRD features activated - Nokia SPRD tab Activated Flash Dump feature Support another signed base driver ( can be found on support for both x86 and x64 systems ) FlashEngine updated - Nokia MTK SP tab changes Flash Engine updated MT6755 line has been broken in previous release, fixed - Nokia MTK FP tab changes PhoneBook extraction engine updated Flash Engine updated Backup security feature released, allow store device security Restore security feature released, allow restore device security backups Backup now also made during "Identify" During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set ) - Other Minor bugfixes and changes - Additional info SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support. ETA of processing - 48 hours, then files can be found on support. All other ways will be ignored. NEW SPRD DRIVERS should be installed ! https://www.infinity-box.com/support/?r=100066 |
04-01-2019, 09:45 | #1213 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity-Box [BEST] NK2 v1.12 - Nokia 106 (2019) line support activated Next revision of Nokia 106 (2019) are supported: Nokia 106 (2019) : NEMO : TA-1114 For now the next features are supported: > Firmware flashing ( Factory/BEST firmware packages ) > Firmware reading > Format FS / Reset Settings > Identify ( read complete device info & check/verify security area ) > Backup security > Restore security > Repair security ( via SWP ) > SP unlock ( via SWP ) > Complete repair ( via SWP ) *SWP feature allowed due to Nokia security flaw, made in Nokia 106 and affect this model only for now. - Base Loader database updated Bugfixes and minor changes - Support Some firmwares for Nokia 106 can be found on support now https://www.infinity-box.com/support/?r=100068 |
04-09-2019, 10:08 | #1214 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity-Box [BEST] NK2 v1.13 - Universal Flasher/Unbricker, more Forensic and other stuff ! MTK SP tab - Flasher engine updated Allow unbrick/repair almost all SW-related issues during flashing from now ( specially A/B devices ) Fixed memory partitioning issues on fresh devices - Reset Settings/Format FS updated - Safe UserData flashing feature updated - Pre-Erase option can be activated/de-activated depend on user need MTK FP tab - Dead mode flashing revised ( incorrect identification during flashing semi-dead device ) - Firmware reader engine updated - LangPack info extractor updated - Forensic engine updated Nokia 106 PhoneBook extraction activated/de-activated Universal Gallery extractor activated *Allow extract : Photos ( if device have camera ) , Audio records , Browser BookMarks and History ( Built-in MTK and Opera Mini supported ) *Support all existing MTK Feature devices, made by Microsoft and HMD Nokia *Support Direct (from phone) and Dump (from file) mode Phonebook extraction updated SPRD FP tab - FullFlash reading optimized Unfortunately, all dumps, made by v112 are not usable. Please, repeat reading with new version, if you need get LangPacks. - Flash Engine updated - NVRAM verify and check revised Other - Some bugfixes and changes Support - All latest firmwares can be found on support ! https://www.infinity-box.com/support/?r=100069 |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
04-15-2019, 09:20 | #1215 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity-Box [BEST] NK2 v1.14 - Nokia 210 (2019) Full support activated Next revision of Nokia 210 (2019) are supported: Nokia 210 (2019) : TA-1139 For now the next features are supported: > Firmware flashing ( Factory/BEST firmware packages ) > Firmware reading > Format FS / Reset Settings > Identify ( read complete device info & check/verify security area ) > Backup security > Restore security > Repair security ( via SWP ) > SP unlock ( via SWP ) > Complete repair ( via SWP ) > Forensic ( Gallery/Browser History/Browser BookMarks ) *SWP feature allowed due to Nokia security flaw, made in Nokia 210 and affect this model only for now. *CROSS-SWP between affected models not allowed for now! - Base Loader database updated Bugfixes and minor changes - Support Some firmwares for Nokia 210 can be found on support now https://www.infinity-box.com/support/?r=100070 |
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:-@ | nejm | UST Pro II | 5 | 01-26-2010 09:30 |
30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported | Infinity-Box | Service Products News & Updates | 0 | 04-30-2009 14:46 |
..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. | Mizar | Cruiser Suite | 4 | 12-11-2008 12:01 |
Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : | Infinity-Box | Infinity-Box | 2 | 07-26-2008 09:55 |
