Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #901 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: infinity-box
Member: 1043909 Status: Offline Thanks: 8,922
| 19-06-2012: MModule v4.33 released .Lanix-LX5 model supporrted (flash read/write, sp-unlock, user code, repair, emptyboard flashing) |
| | #902 (permalink) |
| 20-06-2012: Beeline and Huawei models updated .Beeline-A103 model supported (unlock codes reading) .Huawei-G5510 model supported |
| | #903 (permalink) |
| 06-07-2012: Huawei and Alcatel models updated .Huawei-G6609 model supported .Alcatel-OT217D code calculation improved .security area repair improved (8 new firmwares supported) .firmware database updated |
| | #904 (permalink) |
| 18-07-2012: Infinity-Box Nokia [BEST] v1.48 released - USB flashing improved - BB5 USB loaders updated - MSM72x flashing (Lumia 610) was broken on previous release, fixed - Added ASIC check for BB5, from now not possible flash wrong firmware (e.g. RAP4 to BCM and others) - Maemo/Meego flashing revised, work now on XP without problems - Maemo (N900) error handling added (if will be errors, like CMT,APE, e.t.c. faults, BEST show reasons and way to fix them) - RPL reading during flash improved for XG213 - MeeGo eMMC only flash improved - MeeGo USB loader updated - Service operations improved - Improved XG213 RPL reading - Added SelfTest option for Lumia series (battery/power/e.t.c diagnostic) - Fixed hang during PM read/write on some models - During Cam Check/Repair also will be done HW check (Detect HW fault, show reasons of error) - For CNT reset added default SL tables for XG213 phones (replace/repair damaged tables, CS repair after bad reset) - XG110/DCT4+ reset user code improved ( set to default 12345 without data lost / full reset) - New Operator/Country info with new base (BB5/Infineon - Lock info) - Security repair for N73 improved (res tore ccc/hwc) - SL3 simlock extraction improved sl: Added support for new types sl: Added new way of rpl validation during recovery sl: Added support SL3/SL30 simlock extraction even from working , but SL damaged phones (!!!in SOME cases!!!) sl: Added auto rpl complete in some damage cases sl: Added support for locked phones (under test) sl: Improved SL3 simlock extraction and pre-validation sl: Rewriten SL30 simlock extraction sl: Added SL30 simlock pre-validation sl: SPR reading improved sl: Revised support of override SL types (skip not SL3/SL30 phones) As always, simlock present check for free, so, handjob lovers can find some more things now - User data operations improved - Added support for new-type XG213 phones (110,111,112 and same) XGnew: Phonebook backup/extract/write XGnew: LifeTimer edit XGnew: Gallery backup XGnew: SMS read/write/extract - Improved s4pb format - full cross-writing between BB5 S40 , DCT4+ ARM (XG213) , DCT4+ - Improved SMS/Gallery/PhoneBook extraction from phones with partialy damaged FS - Improved Phonebook/Gallery/e.t.c extraction for some S40/S60 models f rom FullFlash - Improved data extraction from fullflash from S40/S60/S^3 models - Improved PhoneBook reading from BB5 S40 phones (C3 bug and some others fixes) - Fixed freeze during extraction on some model (Note! some big-sized (512,1024mb flash - can take up to 10-20-40 minutes!) - Low Format fixed for 8800 arte - Other - Maemo flashing from Normal (powered on state) mode fixed - MeeGo/Maemo flash file info added (region, langs, PR version, e.t.c) - Improved flashfiles check (Maemo/MeeGo/BB5/Lumia/Infineon) - Fixed VPL parser (modem part clear and file checking for Lumia) - RSA check improved (added new models) - INI revised - Some bugfixes - New WP7 models added (L610c) - Updated WP7 wipe files - Updated stuff files (tune/rpl) |
| | #905 (permalink) |
| 25-07-2012: CDMA-Tool v1.88 released .ZTE-S185 new firmware supported, COMPILE date unlock "Sep 13 2011 (16:04:01)" .Unicare-201A unlock operation released |
| | #906 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| 03-08-2012: BlackBerry code calculation service updated .Infinity-Box Online Service updated .BlackBerry code calculation service updated 08-08-2012: "Calculator" v1.17 released .ZTE-S202-VTecla firmware 16 digit NCK code calculation |
| | #907 (permalink) |
| 09-08-2012: "Calculator" v1.18 released Pantech unlock code standalone calculator released: .Pantech-C600 .Pantech-C610 .Pantech-C630 .Pantech-C740-Matrix .Pantech-C790-Alladin-Duo .Pantech-C810-Duo .Pantech-C820-Matrix-Pro .Pantech-P1010 .Pantech-P2000-Breeze-II .Pantech-P2010 .Pantech-P2020-Ease .Pantech-P2030 .Pantech-P5000 .Pantech-P6010 .Pantech-P7000-Impact .Pantech-P7040-Link .Pantech-P7040P .Pantech-P8000 .Pantech-P9020-Pursuit .Pantech-P9050-Laser |
| | #908 (permalink) |
| 10-08-2012: "Calculator" v1.19 released Unlock code standalone calculator for the next models released: .Avvio-SN50 model supported .Avvio-SN70 model supported .Avvio-410 model supported .Avvio-T519 model supported .GTran-N120 model supported .GTran-N510 model supported .MessagePhone-QS150 model supported |
| The Following User Says Thank You to InfinitySupport For This Useful Post: |
| | #909 (permalink) |
| 11-08-2012: "Calculator" v1.20 released .Mojo-Chat (Mojo-C200) model supported .Huawei-G5510 operations improved 11-08-2012: BlackBerry code calculation service updated .BlackBerry code calculation service updated with latest MEPs |
| The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
| | #910 (permalink) |
| 12-08-2012: Infinity-Box CDMA-Tool v1.89 released .Huawei-E352 unlock code calculation .Huawei-E367 unlock code calculation .Huawei-E173 unlock code calculation .Huawei-E353 unlock code calculation .Huawei-E353WS unlock code calculation .Huawei-E353WS-2 unlock code calculation .Huawei-E357 unlock code calculation .Huawei-E362 unlock code calculation .Huawei-E372 unlock code calculation .Huawei-E368 unlock code calculation .Huawei-E398 unlock code calculation .Huawei-E1732 unlock code calculation .Huawei-E392 unlock code calculation .Huawei-E1815 unlock code calculation .Huawei-E1731 unlock code calculation .Huawei-E173u-2 unlock code calculation .Vodafone-K4510 unlock code calculation .Vodafone-K4511 unlock code calculation .Vodafone-K4605 unlock code calculation .Vodafone-K5005 unlock code calculation NOTE: some customized firmware may be not supported yet |
| | #911 (permalink) |
| 13-08-2012: Lanix, Coral, PCD models updated .Lanix-Z11 model supported (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .Coral-266 model supported (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .PCD-CL1136EN model supported (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .Alcatel/Vodafone-252 unlock operation improved .security area repair improved (34 new firmwares supported) .firmware database updated |
| | #912 (permalink) |
| 15-08-2012: iPhone Network + Simlock status check released via Infinity-Box Online Service .Login into Infinity-Box Online Service .Enter imei .You will see SimLock status and Network Operator name |
| | #913 (permalink) |
| 17-08-2012: Infinity-Box Nokia [BEST] v1.49 released - USB flashing improved - (BB5) AfterFlash operations improved - Service operations improved - Added One-click SECURITY repair for XG213 phones! - Added Unlock codes extraction from locked dead phones on Restore SL! - SL3 simlock extraction improved sl: Added support for new types sl: Improved SimLock validation during recovery sl: Added Unlock codes extraction from dead phones sl: Improved detection for locked phones sl: Improved SimLock extraction from locked phones for SL3/SL30 sl: Improved SPR reading sl: Override SL detection improved - Read RPL for XG213 improved ( for Asha 3xx series ) - Improved easy RPL Write/Read for XG213 - Fixed errors/hang/phone reboots on PM read for XG213 phones - PP repair improved for XG213 phones - User data operations improved - Added support for new-type XG213 phones (Asha 305, 306 and same) XGnew: Phonebook backup/extract/write XGnew: LifeTimer edit XGnew: Gallery backup XGnew: SMS read/write/extract - Other - INI revised, added new models - Stuff files updated (PP/Tune/HWC/Wipe) - LBF comand files create fixed for latest OCLHashCat versions - New WP7 products added (RM-849) - Some bugfixes |
| | #914 (permalink) |
| 18-08-2012: Infinity-Box Nokia [BEST] v1.50 released - USB flashing improved - (WP) Lumia flashing improved - Service operations improved - SL3 SImlock Extraction/Recovery now Free and Standalone! sl : Added support for new types sl : SimLock verify improved sl : SPR reading improved sl : some old rapido extraction was broken since from v1.46, fixed sl : SimLockCode extraction improved sl : Speed up of extraction sl : SimLock complete improved in some damage cases sl : Save SimLock in RPL and PM formats - User Data operations improved - SMS extraction from S60vX/S^3/Anna/Belle improved - Other - Some bugfixes - Ini updated |
| | #915 (permalink) |
| 23-08-2012: Infinity-Box Nokia [BEST] v1.51 released - Service operations improved Added CMLA key check (BB5 S40 / BB5 S60 / XG213) Simlock Recovery improved -Added support for new types Improved locked phones detection/extraction Improved simlock validation during recovery Added SimLock recovery directly from phone Improved SPR reading - Other Ini updated Stuff Files updated Some bugfixes and minor changes |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| @-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:-@ | nejm | UST Pro II | 5 | 01-26-2010 08:30 |
| 30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported | Infinity-Box | GSM News & Updates | 0 | 04-30-2009 14:46 |
| ..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. | Mizar | Cruiser Suite | 4 | 12-11-2008 11:01 |
| Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : | Infinity-Box | Infinity-Box | 2 | 07-26-2008 09:55 |
