Old 10-09-2018, 15:28   #1201 (permalink)
Member: 1043909
Thanks Meter: 48,917
Infinity `SM` software v2.03 released
Flashing - partitions list updated to support newest models/devices for flashing
Intrface bugs fixed
Included new procedure to support new FRP Reset method (in test, comming soon)
https://www.infinity-box.com/news/?r=1258
The Following 5 Users Say Thank You to YellowBoss For This Useful Post:
Old 11-06-2018, 08:07   #1202 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,066
Infinity `SM` software v2.04 released
Flasing - add Reset userlock / pin / pattern / password in FRP ON + OEM ON mode options
Many bug fixed
How to use Reset User lock options:
- see phone version in Recovery menu
- download COMBINATION file according to the phone version
- check checkbox and add your COMBINATION file
- flash phone
- after write COMBINATION file wait phone is turned on
- phone on in recovery mode, reboot phone
- you have access to phone data
after backup user data - reflash phone
https://www.infinity-box.com/support/?r=100050
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 11-07-2018, 00:23   #1203 (permalink)
Member: 148515
Thanks Meter: 13,329
Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features
Important:
- Software installed to new folder /CM2MT2/ and designed to support new models
Legacy core support activated:
MT6571
MT6572
MT6580
MT6582
MT6589
MT6592
MT6595
MT6597
MT6732
MT6735
MT6737
MT6752
MT6753
MT6795
MT8127
MT8163
MT8321
MT8732
MT8735
MT8752
Identify: full device info, security info
Flash Factory Firmware
Read Factory Firmware
Reset Settings / Format FS
Reset FRP
Repair Security (Flash Mode, Direct)
SP unlock
MemoryTool - complete device control, service, repair, forensic etc.
- Main
Loader database optimized, size reduced.
DA v1820 line support tested and activated
DA v1836 line support tested and activated
Connection level revised
BROM level support optimized
Optimized and changed HighSpeed port selection
FlashEngine revised
NVRAM tool revised
Global option PWM - allow switch SW between two different work modes for RAPHAEL.
> Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc.
> For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE )
- Service
Repair Security revised
> Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes !
Format FS - new mode activated: Forced Erase
Format FS - fixed WIPE mode
- Core
EMIDB updated
New EMI engine for LEGACY line
> EMI engine support almost all existing LEGACY line
> New types for RAPHAEL included
- FW reader
LEGACY core supported ( unsigned and static signed types are supported )
New types of firmwares supported
Scatter creation optimized
- Other
Settings tab activated ( firmware path settings and other features can be found here )
AutoUpdate ( module files ) feature activated
Many other changes and fixes
Known issues/warnings/info:
1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list.
2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list !
3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed.
4. MT6592 support on DAv18xx loader line broken ( DA issue )
5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP )
6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC )
7. NAND support on LEGACY line is not activated yet
https://www.infinity-box.com/support/?r=100051
The Following 4 Users Say Thank You to InfinityHelp For This Useful Post:
Old 11-12-2018, 06:33   #1204 (permalink)
Member: 148515
Infinity Chinese Miracle-2 MTK/Mediatek v2.02 - new features, loaders, improvements
- Base
Base - Read info from EMI base (preloader) in manual mode after selection
Base - Info reading improved ( in some cases device info can be empty )
Base - Manual mode selection revised ( Boot fail issues in manual mode )
- MemoryTool
MemTool - Partition types detection improved
MemTool - Interface changes ( partition selection style changed, menu sctructure changed )
MemTool - work with boot1/boot2 section revised for LEGACY line
MemTool - InitPreloader option activated ( LEGACY/RAPHAEL )
MemTool - Flash service regions read/write now allowed ( if they not set as protected - i.e. OTP )
- Flasher
Flasher - Removed "Skip preloader" option, use selection instead ( untick preloader from flashing list )
Flasher - Customization model revised
Flasher - DL Fix / ADL Checksum revised
Flasher - Preloader initialization during flashing revised
Flasher - More accurate PMT/GPT rebuild, for compatibility with SPFT ( PMT invalid issues after servicing with MT2 module )
- Firmware Reader
FWReader - Scatter compatibility for spft optimized (6735, 6737)
FWReader - More types supported for safe read
FWReader - Info reading improved ( in some cases device info can be empty )
FWReader - SW path settings also accepted now on FW read
- Platform changes
Platform - MT6589 support optimized
Platform - MT6592 support optimized
Platform - MT673x support optimized
- Loader database
LoaderDB - New agents included ( BQ, TECNO, INFINIX, VIVO )
- Other
Other - Lot of small fixes and changes, reported by users
Thanks to : gracy_elec, kamal_singla and other our users for providing files and/or testing
https://www.infinity-box.com/support/?r=100052
Old 11-21-2018, 10:36   #1205 (permalink)
Member: 1043909
Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features
- Forensic engine for MTK feature line devices rebuild from scratch
Allow extract phonebook memory from alive/dead/semi-dead devices
From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions )
> Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode
Extraction is direct (from device) and from dump
Support unicode
All existing MTK FP models are supported now for PhoneBook extraction:
Nokia 108: RM-944, RM-945, RM-1124
Nokia 220: RM-969, RM-970, RM-971, RM-1125
Nokia 225: RM-1011, RM-1012, RM-1043
Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
Nokia 215: RM-1110, RM-1111, RM-1112
Nokia 105: RM-1133, RM-1134, RM-1135
Nokia 222: RM-1136, RM-1137
Nokia 230: RM-1172, RM-1173
Nokia 216: RM-1187, RM-1188
Nokia 150: RM-1189, RM-1190
Nokia 3310(2G): TA-1008, TA-1030
Nokia 105(2017) : TA-1010, TA-1034, TA-1037
Nokia 130(2017) : TA-1017, TA-1019
- Changes/Fixes
> MTK FP line
Fix/Change: Flash engine revised
New feature: SW version check during flashing activated. SW will verify data between phone and VPL.
> In case of device dead ( no SW version data available ) - SW will warn about it.
New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify )
> MTK SP line
Fix/Change : Flash engine revised
Fix/Change : Repartition may fail during NK1 flashing, fixed
Read more here
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 12-06-2018, 09:27   #1206 (permalink)
Member: 1043909
Infinity Samsung `SM` v2.05 released
Service: added new version of Reset FRP procedure (without user-data lost)
How to use: check "new" checkbox and follow instructions
https://www.infinity-box.com/support/?r=100058
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:[email protected] nejm UST Pro II 5 01-26-2010 09:30
30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported Infinity-Box Service Products News & Updates 0 04-30-2009 15:46
..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. Mizar Cruiser Suite 4 12-11-2008 12:01
Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : Infinity-Box Infinity-Box 2 07-26-2008 10:55
Page generated in 0.30116 seconds with 8 queries
