12-09-2008, 10:02 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | lg kg300 restarting solved with format also pinfinding with pinfinder software version: 1.16 cable type: HF 4 pin (L4A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 4, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6227 result: Rx:3 Tx:2 time required: 4 sec Power On ! logs of format and restore imei COM5 [VCP0] selected module v2.48 Action: reset settings Model: LG-KG300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:1A41:C6B6 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: 7S-7312-IN00-0-R1A Version: EP1 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 201 warning: wrong packet cs warning: wrong packet cs items cleared: 201 of 201 building list... done Action: imei Model: LG-KG300 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: EP1 Software version: 7S-7312-IN00-0-R1A" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 352834010153837 verification Ok Finished, time used: 30 sec Power off phone now ! |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
12-09-2008, 10:28 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @joni_rajpura Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
-: Lg kg300 restart prob solv by infinity :- | debmobile | Infinity-Box | 3 | 02-11-2009 16:05 |
LG KG300 Restart Problem! | Was33m | LG | 13 | 12-13-2008 06:44 |
Lg Kg300 Restart | alfin5557 | Infinity-Box | 15 | 08-15-2008 13:06 |
LG kg300 restarting problem | sphameed | LG | 4 | 02-24-2008 16:50 |
LG KG300 Restart Problem | Miftahudin | Infinity-Box | 3 | 09-25-2007 18:51 |
