05-29-2010, 04:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: India,Maharashtra
Member: 890991 Status: Offline Thanks Meter: 146 | Urgent help on Micromax X1i+ flashing error I m Having one micromax X1i+ in dead condition. Picked up flash files from support area, phone flashing 100% but not powering on. I trwied to write EEPROM /FFS, but here is log, it is completing 96-99% & showing error. What does it mean. COM6 [VCP0] selected module v3.39 Device: Micromax-X1i+ Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Micromax-X1i+_ffs_01.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5551:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TBG220612_6532_PCB01_GPRS_MT6223_S00.220612_6532_V 1409.BIN project-id: 220612_6532_V1409, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Eeprom/ffs flash: 98009600000000:2BEA0000000000 Write: Eeprom/ffs error: error# 0000006C error: flash write error: 007F0000:00002000 error: error# 0000002C error: flash write error: 007F0000:00002000 error: write operation failed Write Fail Finished, time used: 2 min 43 sec Remove/Install battery now ! please help urgent needed. |
05-29-2010, 07:41 | #2 (permalink) | |
If flash chip can not be written at one the same address only - in most cases it's a damaged flash chip (damaged or bad soldered flash chip). | |
05-29-2010, 08:36 | #3 (permalink) | |
Member: 890991 Status: Offline Thanks Meter: 146 | Quote:
I will try in hardware. but reading flash 100% ok. should I change flash chip? | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
