11-13-2010, 12:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: TUNISIA
Member: 1114818 Status: Offline Thanks Meter: 247 | urgent .to infinity team after tray to unlock sfr 151 my phone is dead now .only power on with white screen i faormat it after that but same prob he the log from unlock operation: COM3 [VCP0] selected module v3.64 Device: SFR-151 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4A1C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW3_SW2_V7_05.BIN project-id: Z525.C136.HW3.SW2.V7.05, 00000000 code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs_20101113-123030.B0E.bin flash: EC227E22632260:2CEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .............................. required data found flash: EC227E22632260:2CEA0000000000 flash: EC227E22632260:2CEA0000000000 Write: area 1 (pass 1) .................................................. ................................................ area 1 patch applied Ok Special operation Done ====> Write ... flash: EC227E22632260:2CEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 8 min 50 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to jbenianamohsen For This Useful Post: |
11-13-2010, 12:47 | #2 (permalink) |
Member: 1114818 Status: Offline Thanks Meter: 247 | log from format ffs COM3 [VCP0] selected module v3.64 Device: SFR-151 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4A1C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW3_SW2_V7_05.BIN project-id: Z525.C136.HW3.SW2.V7.05, 00000000 code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs_20101113-124046.B0E.bin flash: EC227E22632260:2CEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:2CEA0000000000 Finalization Done Finished, time used: 6 min 37 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-13-2010, 12:52 | #3 (permalink) |
Member: 1114818 Status: Offline Thanks Meter: 247 | phone is powred on with flash file COM3 [VCP0] selected module v3.64 Device: SFR-151 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4A1C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:2CEA0000000000 flash: Micron/Silicon7 AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW3_SW2_V7_05.BIN project-id: Z525.C136.HW3.SW2.V7.05, 00000000 code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: EC227E22632260:2CEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 58 sec Remove/Install battery now ! i used this file for revive it sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.bin |
The Following User Says Thank You to jbenianamohsen For This Useful Post: |
11-13-2010, 13:15 | #6 (permalink) |
Member: 1114818 Status: Offline Thanks Meter: 247 | phone still locked COM3 [VCP0] selected module v3.64 Action: "sp-unlock" unlock method: smart fast Model: SFR-151 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4A1C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW3.SW2.V7.05 Version: YUANDA23C_09A_HW 86 byte(s) read imei: 35868800000015 connection Ok 193 byte(s) read reading data... reading data #2... building new data... writing data... 181 byte(s) read reading data... 188 byte(s) read building new data... warning: unknown lock mode: BC000000 error: data is invalid Finished, time used: 17 sec Remove/Install battery now ! |
11-23-2010, 12:59 | #7 (permalink) | |
Crazy Poster Join Date: Sep 2009
Member: 1126773 Status: Offline Thanks Meter: 11 | Quote:
For repair you have to flash it with a firmware available in infinity support, phone will power up but phone still locked | |
The Following User Says Thank You to achlhiy For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
