Old 10-03-2009, 10:12   #1 (permalink)
Member: 456932
Thanks Meter: 53
Urgent need OBEE 8696 flash file
i badly need OBEE 8696 (double sim) flash file with eeprom. i already download from infinity support but set is nothing on. So plz any body have backup file plz upload here. thanks in advance
Old 10-03-2009, 22:18   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
post requered firmware version.
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
there you will see Original software version.
Old 10-04-2009, 08:59   #3 (permalink)
Member: 456932
Thanks Meter: 53
hi
Sir i already post it i tell u complete story.That OBEE 8698 (double sim) come to me in hanging fault. I can do it full format then phone on only show first screen. Then i write backup file (ffs_20090928-135628.B0E.bin) 897 kb size. Then phone goes to complete dead. Then i read check detailed information and found that firmware
New firmware detected (v.2.87, database date: 19.07.2009):
MTK25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN.
then i go to support and found only 1 matching firmware (MTK25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W0 8_12__fullflash_20090825-152902_16m_En_Ru_Fr_Es_Th_Vn_Farsi_Pt_Ar.B0M.bin) i download it and write it but set is noting on.
here i show first log when i do full format the set. Plz look specially identification of eeprom.
==== log opened: [9/28/2009 1:52:42 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] Chinese Miracle v2.87
S/N:
Wait...
Device: Autodetect 6205-6227 NOR
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [9/28/2009 1:52:59 PM] ====
COM4 [VCP0] selected
module v2.87
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3A03:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18A59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
standard ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090928-135628.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 211 sec
Remove/Install battery now !
Old 10-04-2009, 10:17   #4 (permalink)
Member: 148515
hello!
can you find same working phone on your local market? just to read out full backup?
seems that our flash file is for different hardware configuration
Old 10-04-2009, 11:35   #5 (permalink)
Member: 456932
Thanks Meter: 53
No at the moment i not found matching set in my local market. So i need ur support to request users who found that set or backup file. plz upload here.
Urgent need OBEE 8696 backup file malikawan CPF-BOX Ⅱ 2 10-13-2009 08:28
Urgent need OBEE 8696 file malikawan Chinese Models & Cloned Phones 0 10-03-2009 09:44
urgent need m55 v10 flash files centrino E-Gold Based Phones 3 11-27-2004 02:06
Urgent need T29s AVR flash file?!?!!! benjaminok Old Ericsson Phones & Sony Phones 5 09-12-2004 19:52
urgently need S35 0504 flash file Honza x1x to x45/x50 0 10-05-2000 23:16
Page generated in 0.20484 seconds with 10 queries
