04-27-2009, 17:47 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | urgently: China iPhone unlock : Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: KCM25_GEMINI_HW Software version: A998_FOR_V01_2008072 : https://forum.gsmhosting.com/vbb/f457/china-iphone-model-f9-dual-sim-unlock-718441/ What cable I need? Cable#19: 1x5 pins (mini-usb): connected directly to infinity box? Last edited by microera; 04-27-2009 at 17:50. Reason: more info: model: F9, dual SIM, 8GB |
04-28-2009, 12:44 | #2 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | Finaly I can read data from phone (PinFinder is very good tool): ------------- read detailed information: COM31 [VCP0] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ...................... detect standard fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ...................... detect standard fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... detecting firmware build... .................................................. ... firmware build: 200807261828 detecting product-id... .................................................. .............. done detecting languages... .................................................. .............. error: can't detect language parameter #1 warning: can not detect language names if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation. Check firmware content Done Backup required data ... Finished, time used: 117 sec Remove/Install battery now ! but I cant READ codes: ------------------------ read code: COM31 [VCP0] selected module v2.81 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 80 sec Remove/Install battery now ! |
04-28-2009, 14:16 | #3 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | I make: unlock metod: standard and seems to be all ok....but: still: no signal and I can't unlock lcd (with sliding finger from "left to right") ?! Can anyboy tell me wich frequency have this model of iPhone ... A1203 900 / 1800 / 1900 ? |
04-28-2009, 20:51 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup for emergency case try to make format FFS complete. if will not help- you can try flashing with available on support area flash files |
China iPhone Pin | pusulateknik | Z3X-Team Products | 9 | 07-10-2012 16:44 |
China iPhone model F9, dual SIM unlock | microera | Chinese Models & Cloned Phones | 7 | 07-03-2010 08:10 |
iphone unlock help for bigners | Mind Power | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 03-29-2010 17:05 |
