Old 06-21-2016, 12:24   #1 (permalink)
Member: 341568
Thanks Meter: 9
USBDL : Error init HSUSB!!!
help error on HSUSB
here is the test results
Operation : HW Test [ v1.50 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 15010051375853414201AAADCADB12E9
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BASX7
[eMMC] : FLASH_CID : 15010051375853414201AAADCADB12E9
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xB2DEA26A05BECF6B06CCA52456297E7B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 4118 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BASX7 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 15010051375853414201AAADCADB12E9
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:03:21
Reconnect Power/Cable!
this the result if i going to write the new firmware that i already tested to other same unit.
Operation : Flash [ v1.50 ]
======= Flash
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : sinsoft92_cwet_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
****ch to HSUSB failed! Trying skip ...
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : Unknown (not supported or without battery)
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase Error! Something went wrong!
Operation Failed
Elapsed: 00:00:27
The Following User Says Thank You to reynaldkatkat For This Useful Post:
Old 06-21-2016, 17:43   #2 (permalink)
Member: 2082450
Thanks Meter: 1,430
Start checking with charge battery.
Old 06-28-2017, 15:24   #3 (permalink)
Member: 1737002
Sonork: 1612611
Thanks Meter: 2
I have the same thing please help ZTE A520
PHP Code:
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID 6737
BB_CPU_NME
: [MediaTekMT6737M|MT6737_S00
BB_CPU_EXT
0xCB00 0x8A00 0x0000
Settings
SecCfgVal 0x01000000
BromVer
0x0005
BLVersion
0x00FE
PreLoader
NOT Active Erased ]
BootLdrSS SIGNED with SPRELOADER
Processing DA stage
DA Select done
will use MTK_AllInOne_DA_v5.1624.16.07
Sending
Running DA ver.4.2 on BBID 0x93
NAND Flash
NOT INSTALLED
eMMC Flash
460001154D32584EFE5D0642551E78CC
Initialize Memory
DRAM configured from IDB!
DRAM size 0x40000000
DAgent sent
init HW now
[eMMC] : FLASH_VEN 0x15 OEM 0100
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID 150100464E58324D42065DFECC78C355
[eMMC] : FLASH_BRT 0x00400000 0x00400000 0x00080000
[eMMC] : FLASH_LEN 0x00000001D2000000
[eMMC] : FLASH_UCP 7456 MiB [eMMC 8 GiB]
DEV RID    0xCACE50E2A0A7CFFC80873070EE4C32BF
INT RAM
0x00020000
EXT RAM
0x40000000 [1 GiB]
BOOT TYPE  EMMC_FLASH_BOOT
SOC VERIFY
C1
Boot Ok
USBDL Error init HSUSB!!!
Operation Failed
Elapsed
00:00:25
Reconnect Power
/Cable
Page generated in 0.23748 seconds with 7 queries
