UTstarcom GPFE1258CP problem to unlock Please add this model i try any metod and not unlock the phone see log: COM7 [VCP0] selected modulo v3.81 Servicio: UTStarcom-GPFE1258 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard fast ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:ABFE:000C status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC240200000000:2AEA0000000000 Flash Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required startup code area #1 record #2 is damaged, recalculation required rom info detection finished device-id: 780F6011 rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN project-id: C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG, 7576209F code offset: 00000000 ffs offset/size [01]: 00B40000/004C0000 rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent ffs/eeprom address assigned: 00B40000 startup code area #1 check... rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011._CELLONSZ 23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2011B_1_34_ 0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F207675_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_ S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BI N_9F207675_.rpl ==================== Peligro: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75 Unknown firmware found (v.3.81, database date: 29.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011._CELLONSZ 23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2011B_1_34_ 0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34DFB_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_ S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BI N_C4E34DFB_.rpl ==================== Peligro: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB Unknown firmware found (v.3.81, database date: 29.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash EC240200000000:2AEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... ............................................. error: required unlock parameters not found, check model selection ............................................. error: required unlock parameters not found, check model selection Revisión de datos requeridos Fail Finalizado, tiempo usado: 57 sec Quite/coloque la bateria ahora ! COM7 [VCP0] selected modulo v3.81 Action: "sp-unlock" Metodo unlock: smart fast Modelo: UTStarcom-GPFE1258 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:ABFE:000C status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6223,E05 Dato: 2000.00.00 Version: 1.0 Version: C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG Version: FLASH:SAMSUNGCAMERA:VC0548LCD:ST7687 ==================== New firmware found (v.3.81, database date: 29.03.2011): C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 83 byte(s) read imei: coneccion Ok 189 byte(s) read Leyendo datos... reading data #2... reading data #3... reading data #4... reading data #5... Unknown or damaged lock structure, what to do: 1. repeat operation and press and HOLD "Power" button more long time 2. use another unlock method, f.e. "Metodo unlock: standard" 3. if nothing helps: read flash and send to support: [email protected] error: La operación falló ! Finalizado, tiempo usado: 20 sec Quite/coloque la bateria ahora ! COM7 [VCP0] selected modulo v3.81 Action: read unlock codes Metodo unlock: read codes Modelo: UTStarcom-GPFE1258 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:ABFE:000C status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6223,E05 Dato: 2000.00.00 Version: 1.0 Version: C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG Version: FLASH:SAMSUNGCAMERA:VC0548LCD:ST7687 ==================== New firmware found (v.3.81, database date: 29.03.2011): C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 83 byte(s) read imei: coneccion Ok 189 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 4 byte(s) read error: source data size is less than expected 177 byte(s) read Leyendo datos... 4 byte(s) read Peligro: unknown lock version: 589C41F9 error: La operación falló ! Finalizado, tiempo usado: 18 sec Quite/coloque la bateria ahora ! COM7 [VCP0] selected modulo v3.81 Servicio: UTStarcom-GPFE1258 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:ABFE:000C status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC240200000000:2AEA0000000000 Flash Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required startup code area #1 record #2 is damaged, recalculation required rom info detection finished device-id: 780F6011 rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN project-id: C2011B_1.34_0x11108_US_CLARO_PANAMA_SAMSUNG, 7576209F code offset: 00000000 ffs offset/size [01]: 00B40000/004C0000 rom info structure: [protected] type (07), 2 record(s) TCL-ID is absent ffs/eeprom address assigned: 00B40000 startup code area #1 check... rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011._CELLONSZ 23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2011B_1_34_ 0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F207675_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_ S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BI N_9F207675_.rpl ==================== Peligro: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_9F2076 75 Unknown firmware found (v.3.81, database date: 29.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.780F6011._CELLONSZ 23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C2011B_1_34_ 0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34DFB_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.78 0F6011._CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_ S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BI N_C4E34DFB_.rpl ==================== Peligro: unknown firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN_C4E34D FB Unknown firmware found (v.3.81, database date: 29.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.C201 1B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG.BIN - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo UTStarcom-GPFE1258_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P _S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG__ ffs... Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\UTStarcom-GPFE1258_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223P _S00.C2011B_1_34_0X11108_US_CLARO_PANAMA_SAMSUNG__ ffs_20110401-125410.B0E.bin Flash EC240200000000:2AEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Revisión de datos requeridos Fail Finalizado, tiempo usado: 7 min 9 sec Quite/coloque la bateria ahora ! Full Flash and eeprom link: http://www.gigasize.com/get/5jpdkvg07pc http://www.gigasize.com/get/10l2qcjjvnc |
Hello, Thanks for file. Yes, we heard about similar problems, need some time to check everything carefully. |
for this phones Flash Samsung K5L2833ATA T 16Mb For unlock use, chinese miracle, type original imei, and set default inside imei firmware and go!!! later insert other sim and pres 12345678 and ok....cellphone unlocked |
is posible repair, only thing need, your need know use your infinity box :) |
Please, post here step-by-step instruction for all users. Thank you in advance ! |
Copy the firmware of the phone, select the MModule UT 1258 and the tab will give service and read firmware .. We're going to chinese miracle and select Other chinese model and always unknown tab and write imei service we put Phone the same but with the default option imei inside and we write .. after that he tried a chip from another company and we request I just put a password 12345678 and ready ... and finally we write the firmware we had copied ... In 1258 UT MModule Flash tab load the firmware give written and ready .. This is also for the UT198 We must make a copy of each phone firmware .. |
Need fast metod to unlock.... |
it's something to resolve this is for the time solicion unless you find another solution more effective, or have them with invalid imei ... |
i have a problem with a PCD gpfe1258cp from panama i followed this instructions and after using chinese miracle phone unlocks but when i flash the phone to take care of the imei error the phone is locked again. this phone says pcd not utstarcom |
If yes, send it to [email protected] |
i just sent you the flash backup file |
any updates on firmware sent for PCD gpfe1258cp? |
