05-27-2008, 06:01 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: bali island Age: 43
Member: 137049 Status: Offline Thanks Meter: 7 | v170 flashing error... this log appear on infinity modules. whats the problem..... thanx COM8 [VCP0] selected "repair mode" active "smart write" active "soft restore" active "safe mode" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom continue w/o "safe mode" Device: V170,V171,V172,V173 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 230400 Set Baud Done Check Flash-1... SW version: 9.1.28>. HW version: ]OTORO\A_C071 Flex ver: VLUX_90_61_1007 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20080527-005745.20E.bin Check Flash-2 Done Write... Writing: Firmware "safe mode" active error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: erase failed[67] at 00020000 error: Error during write: 00020000 Write Done Failed ! Finished, time used: 34 sec Remove/Install battery now ! Br, hkyrace |
05-27-2008, 08:54 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see there is a errors during information reading (incorrect phone version information). It may be that something bad with phone hardware. What was initial phone state ? |
05-28-2008, 03:37 | #3 (permalink) |
Member: 137049 Status: Offline Thanks Meter: 7 | i read information,i got this: COM8 [VCP0] selected "repair mode" active Action: read information Device: V170,V171,V172,V173 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 9.1.28>. HW version: ]OTORO\A_C071 Flex ver: VLUX_90_61_1007 Check Flash-1 Done Check Flash-2... Finished, time used: 11 sec Remove/Install battery now ! phone working good before, only lock to tracfone. |
05-28-2008, 09:12 | #4 (permalink) | |
Please double check that no phone hardware was damaged duting track cut procedure | |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
V170 flashing problem | MAK_US1977 | Motorola ODM | 5 | 04-03-2006 21:30 |
MOTOROLA V170 flashing? | P1C1 | Smart-Clip | 2 | 12-23-2005 15:00 |
BE3 v170 flash AMD file needed | dj.kost | Alcatel & TCL Old Models | 1 | 04-10-2002 08:46 |
