05-20-2009, 03:12 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268154 Status: Offline Thanks Meter: 40 | v170 s/w7.5.63 error in repair module after track cut v170 7.5.63 from tracfone working fine before the track cut. i did cut the track like the manual and the phone is detected in repair module but show me the next errors: COM4 selected Device: Motorola V170,V171,V172,V173 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Repair data Flash: 0089:8855 Err: answer#00 try#1 to recover write error at 0001A000 Err: answer#00 try#2 to recover write error at 0001A000 Err: answer#00 try#1 to recover write error at 0001C000 Err: answer#00 try#2 to recover write error at 0001C000 Err: answer#00 try#1 to recover write error at 0001E000 Err: answer#00 try#2 to recover write error at 0001E000 Writing Done Finished, time used: 93 sec Remove/Install battery now ! after that, i cant flash it any way cause is not detected: COM4 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom continue w/o "safe mode" "smart write" active Device: V170,V171,V172,V173 Checking data, wait... Connect... Press and HOLD Power button... Err: boot failure[02]: 00 Release Power button ! Connect Fail Failed ! Finished, time used: 61 sec Remove/Install battery now ! where is my mistake?? some ideas?? |
The Following User Says Thank You to ybru For This Useful Post: |
05-20-2009, 21:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not be connected in "repair" mode it's a cable problem or empty battery or damaged phone hardware. Phone should be detected by software in "repair" mode (cutted track) in any case, not depends on flash chip content. |
05-26-2009, 02:33 | #3 (permalink) |
Member: 268154 Status: Offline Thanks Meter: 40 | thank u for replay, phone is working and battery is ok, so i think thats not the problem. about the cable, already tested with 3, one COM and 2 rj-45. ill try with another cable any way. br |
Error in treo module [SOLVED] | lui_naranjo | FuriousGold | 9 | 06-10-2009 21:37 |
error in other modules | tolski | FuriousGold | 1 | 07-14-2007 02:21 |
C62 error in c62inside module | Freshbol | MT-BOX | 4 | 05-13-2007 16:03 |
error in main module contact seller | spinksy15 | ARM9 BASED M62 / M62+ | 4 | 04-07-2004 17:26 |
