01-18-2008, 11:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | v170 tracfone 9.1.28 converted , but no signal. v172_5.7.19_Main.20M V172_5.7.19_Flex_90_61_2T03.20F V172_5.7.19_LPLA_Es_Pt.20P Replacing resistor, until band selection become 900.1800 Mhz. Jumper the filter. But still no Service. Is this fault has something to do with software ? Flex file ?? Or i have ****n the CPU while removing N1 testpoint ?? need help. |
01-18-2008, 13:46 | #3 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | is the display will be ok?? because i flashed this phone using v172 to repair bad display. and one more thing. after removing test point do i have to put it back (N1) ?? Because i have done 2 pphones c 139, new type from trcfone, after flash and unlock done, the phone lose opening screen. After i press ON button, there is no opening screen from MOTOROLA, and it shows Insert Card only, without light. After i pressed another button, light came up, and phone can still be used as normal phone after that. thx |
01-19-2008, 03:20 | #5 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | RESULT : after flash with firmware v171 4..x..x , ( any version of it ), signal is GOOD. But display is BAD. Any other firmaware to get my display back ? |
01-30-2008, 21:35 | #11 (permalink) |
Junior Member Join Date: Sep 2007 Location: Quetzaltenango, Guatemala C.A. Age: 37
Member: 592213 Status: Offline Thanks Meter: 0 | test point image for V170? if someone could help me or give me the image for a test point of a motorola V170 please, i would appreciate that, thanks! |
03-03-2008, 11:07 | #13 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | I just found the solution for bad display after flashing the phone w 4.7.19 firmware, lang, and flex. All you have to do is just flash the phone w/ v172_5.7.19_Main.20M only. Then post the result. Don't flash the phone w lang and flex file coz it will erase the 4.7.19 lang and flex file from phone that will result to no network or bad display. |
V170 TRACFONE v9.1.28 need help step by step | bachatia | Infinity-Box | 1 | 04-03-2008 09:31 |
V170 9.1.28 can not boot with dmtool. | Celhack | Motorola ODM | 0 | 07-07-2007 13:43 |
Cant flash v170 9.1.28 from Tracfone | tele f0n3 | Infinity-Box | 6 | 04-03-2007 19:22 |
c139 tracfone already unlocked but no signal | cora | Infinity-Box | 1 | 10-17-2006 06:15 |
Plz update to unlock Motorola V170 Ver: 9.8.28 | Christobol_007 | Infinity-Box | 3 | 06-24-2006 04:34 |
