-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   v170 tracfone 9.1.28 converted , but no signal. (http://forum.gsmhosting.com/vbb/f296/v170-tracfone-9-1-28-converted-but-no-signal-491729/)
[email protected] 01-18-2008 10:44
i flashed with V172:
v172_5.7.19_Main.20M
V172_5.7.19_Flex_90_61_2T03.20F
V172_5.7.19_LPLA_Es_Pt.20P
Replacing resistor, until band selection become 900.1800 Mhz.
Jumper the filter.
But still no Service.
Is this fault has something to do with software ? Flex file ??
Or i have ****n the CPU while removing N1 testpoint ??
need help.
InfinitySupport 01-18-2008 11:05
Hello,
Try to flash it with V171 v4.x.x files set, I think this may helps.
[email protected] 01-18-2008 12:46
is the display will be ok??
because i flashed this phone using v172 to repair bad display.
and one more thing.
after removing test point do i have to put it back (N1) ??
Because i have done 2 pphones c 139, new type from trcfone, after flash and unlock done, the phone lose opening screen.
After i press ON button, there is no opening screen from MOTOROLA, and it shows Insert Card only, without light. After i pressed another button, light came up, and phone can still be used as normal phone after that.
thx
InfinitySupport 01-18-2008 15:02
Hello,
LCD: you need to test it
N1: best way: restore ball
[email protected] 01-19-2008 02:20
RESULT : after flash with firmware v171 4..x..x , ( any version of it ), signal is GOOD. But display is BAD.
Any other firmaware to get my display back ?
mrfixit 01-19-2008 02:24
need to change display and it will be ok
[email protected] 01-19-2008 02:34
hmm.... that will be exppensive .
i guess is better if im waiting for new firmware ( if possible ?)
InfinitySupport 01-19-2008 06:52
Hello,
I am not sure that any new firmware will be released for V17x in nearest future.
[email protected] 01-24-2008 12:57
need info for V170 LCD.
is similar to c139 ???
mrfixit 01-25-2008 00:00
no different, ipmart sell them, better take good lcd out of broken v170 with bad board or so.
tmzmonko 01-30-2008 20:35
test point image for V170?
if someone could help me or give me the image for a test point of a motorola V170 please, i would appreciate that, thanks!
InfinityHelp 01-31-2008 00:29
hello!
C:\Program Files\InfinityBox\Documentation\test_point\Moto
Dj King 03-03-2008 10:07
I just found the solution for bad display after flashing the phone w 4.7.19 firmware, lang, and flex.
All you have to do is just flash the phone w/ v172_5.7.19_Main.20M only. Then post the result. Don't flash the phone w lang and flex file coz it will erase the 4.7.19 lang and flex file from phone that will result to no network or bad display.;)
[email protected] 03-06-2008 04:25
hi bro.... you re my saviour.
thak you... my problem solved.
br
dump101 07-15-2008 19:40
New version V170 tracfone dump...
http://forum.gsmhosting.com/vbb/show...49#post3482849
Full memory dump
New version..
Page generated in 0.28674 seconds with 5 queries
