Old 01-18-2008, 10:44   #1 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
v170 tracfone 9.1.28 converted , but no signal.
i flashed with V172:
v172_5.7.19_Main.20M
V172_5.7.19_Flex_90_61_2T03.20F
V172_5.7.19_LPLA_Es_Pt.20P
Replacing resistor, until band selection become 900.1800 Mhz.
Jumper the filter.
But still no Service.
Is this fault has something to do with software ? Flex file ??
Or i have ****n the CPU while removing N1 testpoint ??
need help.
Old 01-18-2008, 11:05   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,077
Hello,
Try to flash it with V171 v4.x.x files set, I think this may helps.
Old 01-18-2008, 12:46   #3 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
is the display will be ok??
because i flashed this phone using v172 to repair bad display.
and one more thing.
after removing test point do i have to put it back (N1) ??
Because i have done 2 pphones c 139, new type from trcfone, after flash and unlock done, the phone lose opening screen.
After i press ON button, there is no opening screen from MOTOROLA, and it shows Insert Card only, without light. After i pressed another button, light came up, and phone can still be used as normal phone after that.
thx
Old 01-18-2008, 15:02   #4 (permalink)
Member: 130995
Hello,
LCD: you need to test it
N1: best way: restore ball
Old 01-19-2008, 02:20   #5 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
RESULT : after flash with firmware v171 4..x..x , ( any version of it ), signal is GOOD. But display is BAD.
Any other firmaware to get my display back ?
Old 01-19-2008, 02:24   #6 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 767
need to change display and it will be ok
Old 01-19-2008, 02:34   #7 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
hmm.... that will be exppensive .
i guess is better if im waiting for new firmware ( if possible ?)
Old 01-19-2008, 06:52   #8 (permalink)
Member: 130995
Hello,
I am not sure that any new firmware will be released for V17x in nearest future.
Old 01-24-2008, 12:57   #9 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
need info for V170 LCD.
is similar to c139 ???
Old 01-25-2008, 00:00   #10 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 767
no different, ipmart sell them, better take good lcd out of broken v170 with bad board or so.
Old 01-30-2008, 20:35   #11 (permalink)
Member: 592213
test point image for V170?
if someone could help me or give me the image for a test point of a motorola V170 please, i would appreciate that, thanks!
Old 01-31-2008, 00:29   #12 (permalink)
Member: 148515
Thanks Meter: 13,900
hello!
C:\Program Files\InfinityBox\Documentation\test_point\Moto
Old 03-03-2008, 10:07   #13 (permalink)
Member: 6428
Thanks Meter: 43
I just found the solution for bad display after flashing the phone w 4.7.19 firmware, lang, and flex.
All you have to do is just flash the phone w/ v172_5.7.19_Main.20M only. Then post the result. Don't flash the phone w lang and flex file coz it will erase the 4.7.19 lang and flex file from phone that will result to no network or bad display.
The Following 2 Users Say Thank You to Dj King For This Useful Post:
Old 03-06-2008, 04:25   #14 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 40
hi bro.... you re my saviour.
thak you... my problem solved.
br
Old 07-15-2008, 19:40   #15 (permalink)
Member: 806861
Thanks Meter: 92
New version V170 tracfone dump...
http://forum.gsmhosting.com/vbb/show...49#post3482849
Full memory dump
New version..
V170 TRACFONE v9.1.28 need help step by step bachatia Infinity-Box 1 04-03-2008 09:31
V170 9.1.28 can not boot with dmtool. Celhack Motorola ODM 0 07-07-2007 13:43
Cant flash v170 9.1.28 from Tracfone tele f0n3 Infinity-Box 6 04-03-2007 19:22
c139 tracfone already unlocked but no signal cora Infinity-Box 1 10-17-2006 06:15
Plz update to unlock Motorola V170 Ver: 9.8.28 Christobol_007 Infinity-Box 3 06-24-2006 04:34
Page generated in 0.40743 seconds with 8 queries
