07-22-2008, 09:15 | #1 (permalink) |
Junior Member Join Date: Aug 2007 Location: france
Member: 575634 Status: Offline Thanks Meter: 2 | V270 unlock success with infinity Device: Alcatel-V270 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-V270_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V270_eeprom_calibration-1_20080722-105158.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 234 sec Remove/Install battery now ! |
The Following User Says Thank You to khamis rashid For This Useful Post: |
07-23-2008, 10:33 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
09-23-2008, 16:18 | #3 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 436948 Status: Offline Thanks Meter: 4 | COM2 [Serial0] selected Device: Alcatel-V270 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-V270_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V270_eeprom_calibration-1_20080923-211609.80E.bin Read data done Check data... Check data done Writing... error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unknown structure, read flash and send to support ! Writing fail Finished, time used: 121 sec Remove/Install battery now ! |
12-28-2008, 10:42 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | COM12 [VCP0] selected Device: Alcatel-V270 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail Finished, time used: 50 sec Remove/Install battery now ! plz infinity team check this in mostly set v are facing this problem plz try to solve it |
12-28-2008, 10:49 | #6 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | COM12 [VCP0] selected Device: Alcatel-V270 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-V270_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V270_eeprom_calibration-1_20081228-144733.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 78 sec Remove/Install battery now ! problem solved just badurate speed 115200(slow) |
The Following User Says Thank You to Y2ksalman For This Useful Post: |
06-02-2011, 11:07 | #7 (permalink) |
No Life Poster Join Date: Dec 2009 Location: GSMKSA Team
Member: 1178222 Status: Offline Sonork: 100.1602620 Thanks Meter: 467 | @Y2ksalman sir i have same problem how to solve ur problem pls tel me. i try to sp unlock but show booting... finalizing...then after hang on infinity shell after remove battery then show this logo Boot fail error: operation failed Finished, time used: 62 sec Remove/Install battery now ! how to fix this pls help me urjunt COM23 [VZP3] selected module v1.34 Device: Alcatel-V270 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 62 sec Remove/Install battery now ! |
<< F3 unlock success with Infinity >> | zeel_zeel | Infinity-Box | 16 | 01-11-2012 21:32 |
Vodafone 228 unlock successfully with infinity! | kmaxmax | Infinity-Box | 4 | 01-04-2010 20:03 |
T303 unlock successful with infinity box | Parminder Singh | Infinity-Box | 1 | 04-24-2009 07:37 |
kp202 unlock success with infinity!! | ryumahon | Infinity-Box | 10 | 07-23-2008 15:33 |
KP130 unlock success with infinity ... | mughalG | Infinity-Box | 0 | 05-30-2008 14:57 |
