01-14-2011, 20:38 | #4 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Viet Nam
Member: 453984 Status: Offline Thanks Meter: 5 | I flashed 2 files from support (Firmware & EEROM - file date 13-jan-2011) and unlock phone. With Smart fast method : COM3 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Viettel-V6202 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:43E7:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: VE-VN-VT9S-P109A17MV1.0.4B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35276104xxxxxx connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! Unlock log may be OK but phone is still locked. With Standard Method : COM3 [VCP0] selected module v3.72 Device: Viettel-V6202 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:43E7:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.72, database date: 23.12.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN project-id: VE-VN-VT9S-P109A17MV1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs... file saved: C:\Temp\Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs_20110115-022440.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ........................ required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 1 (pass 1) ........................................ area 1 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 39 sec Remove/Install battery now ! After unlock phone with this method, Phone was dead (Show white screen then off) |
The Following User Says Thank You to hiep_hv For This Useful Post: |
01-15-2011, 05:56 | #7 (permalink) | |
Major Poster Join Date: Nov 2010
Member: 1433074 Status: Offline Thanks Meter: 2 | Quote:
01-17-2011, 08:21 | #10 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223499 Status: Offline Thanks Meter: 46 | today unlock same COM52 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Viettel-V6202 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7AE0:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: VE-VN-VT9S-P109A17MV1.0.4B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35276104169592 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
01-18-2011, 04:13 | #11 (permalink) |
Member: 1433074 Status: Offline Thanks Meter: 2 | unlock method: smart fast Model: Viettel-V6202 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C44:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: VE-VN-VT9S-P109A17MV1.0.4B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35276104126917 connection Ok 192 byte(s) read reading data... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! 18-01-2011 bring your lock is unlocked |
01-18-2011, 17:08 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If somebody can make this test, please try this method and post result: 1. make full flash backup for emergency case 2. flash phone with SFR-115 file from support area 3. unlock phone what is the results ? |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
