Old 01-13-2011, 10:10   #1 (permalink)
Member: 1433074
Thanks Meter: 2
V6202 unlock not ok
The new V6202 unlock not ok for double
The Following User Says Thank You to helo_2010 For This Useful Post:
Old 01-13-2011, 10:15   #2 (permalink)
Member: 502531
Thanks Meter: 897
unlock with other method.
post result
The Following User Says Thank You to .:UnitedGSM:. For This Useful Post:
Old 01-14-2011, 13:24   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Please, make this:
1. make full flash backup for emergency case
2. flash phone with another firmware from support area
3. repeat "unlock" operation
Waiting for your results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-14-2011, 20:38   #4 (permalink)
Member: 453984
Thanks Meter: 5
I flashed 2 files from support (Firmware & EEROM - file date 13-jan-2011) and unlock phone.
With Smart fast method :
COM3 [VCP0] selected
module v3.72
Action: "sp-unlock"
unlock method: smart fast
Model: Viettel-V6202
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:43E7:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: VE-VN-VT9S-P109A17MV1.0.4B01
Version: ZTENJ23D_09A_HW
86 byte(s) read
imei: 35276104xxxxxx
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
Remove/Install battery now !
Unlock log may be OK but phone is still locked.
With Standard Method :
module v3.72
Device: Viettel-V6202
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.3.72, database date: 23.12.2010):
ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 07
sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN
project-id: VE-VN-VT9S-P109A17MV1.0.4B01, 00000000
code offset: 00000000
ffs offset/size [02]: 00880000/00780000
TCL-ID is absent
ffs/eeprom address assigned: 00880000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs...
file saved: C:\Temp\Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs_20110115-022440.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
error: phone is not locked or unknown eeprom
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 6 min 39 sec
After unlock phone with this method, Phone was dead (Show white screen then off)
The Following User Says Thank You to hiep_hv For This Useful Post:
Old 01-15-2011, 03:49   #5 (permalink)
Member: 616907
Thanks Meter: 4
v6202 ver 4b01 unlock not ok.
Old 01-15-2011, 04:09   #6 (permalink)
Member: 816254
up, waiting for update
Old 01-15-2011, 05:56   #7 (permalink)
Member: 1433074
Thanks Meter: 2
module v3.72
Action: "sp-unlock"
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
86 byte(s) read
connection Ok
192 byte(s) read
reading data...
reading data #2...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
module v3.72
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
required data found
====> Write ...
Write: ffs
Write Done
Finalization Done
so hiii my ethnicity has always hiii
Old 01-15-2011, 08:38   #8 (permalink)
Member: 657009
Thanks Meter: 20
New ver unlock not ok
Full Flash
Erom
Old 01-15-2011, 10:28   #9 (permalink)
Member: 1433074
Thanks Meter: 2
important is not my friend unlocked
Old 01-17-2011, 08:21   #10 (permalink)
Member: 223499
Thanks Meter: 46
today unlock same
COM52 [VCP0] selected
module v3.72
Action: "sp-unlock"
19200 autodetect
CPU: MT6223
chip: 0011:7AE0:000C
status: FF
Date: 2000.00.00
Version: 1.0
86 byte(s) read
imei: 35276104169592
connection Ok
192 byte(s) read
reading data...
reading data #2...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 14 sec
Old 01-18-2011, 04:13   #11 (permalink)
Member: 1433074
Thanks Meter: 2
19200 autodetect
CPU: MT6223
chip: 0011:7C44:000C
status: FF
Date: 2000.00.00
Version: 1.0
86 byte(s) read
imei: 35276104126917
connection Ok
192 byte(s) read
reading data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
18-01-2011
bring your lock is unlocked
Old 01-18-2011, 17:08   #12 (permalink)
Member: 130995
If somebody can make this test, please try this method and post result:
2. flash phone with SFR-115 file from support area
3. unlock phone
what is the results ?
Old 01-19-2011, 03:14   #13 (permalink)
Member: 507068
Thanks Meter: 3
3. unlock phone
I tried flash file from support and unlock done but still lock
Old 01-19-2011, 04:57   #14 (permalink)
Member: 1454213
please up date!
i have 40 phones (
Old 01-19-2011, 09:08   #15 (permalink)
Member: 665092
Thanks Meter: 6
unlcok is done ...!
but still locked
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.25571 seconds with 10 queries
