Old 05-07-2009, 16:07   #1 (permalink)
best_s_gsm's Avatar
Member: 240499
V670 after flash with SIMFREE is dead
COM5 [VCP0] selected
module v2.73
Device: Alcatel-V670X, V670A
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:C8FA:A000
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.604C5 057.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_29555E37].rpl
New firmware detected (v.2.73, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: support@infinity-box.biz
- send flash backup files to support: support@infinity-box.biz
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 604C5057
identification#1 protocol ver: 05
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V24, C8A1AAD6
ffs offset/size: 01000000/01000000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 35305102066436
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V670X,V670A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_604C5057_29555E37_20 090507-151619.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CC19BJ22
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V670X,V670A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_604C5057_29555E37_20 090507-154901.B0X.bin
Finished, time used: 2049 sec
Remove/Install battery now !
Old 05-07-2009, 21:05   #2 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
repair security Area.......
or ..
wait..new flash...today sent to suppoprt !
The Following User Says Thank You to The_Dj For This Useful Post:
Old 05-08-2009, 09:17   #3 (permalink)
rajesh_ch's Avatar
Member: 618404
change the flash file version & post result..........
Old 05-08-2009, 11:05   #4 (permalink)
best_s_gsm's Avatar
Member: 240499
thanks to all
problem solved by "repair security Area"
Old 05-08-2009, 15:01   #5 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
ok....
Thread Closed !
Nokia n95 8gb after flashing with hwk was dead... Mehdi Ghorbani HWK 21 09-21-2010 21:26
Cu500v After Flash Patch Unlock Is Dead GUDO-GSM FuriouS TeaM Products 9 09-06-2007 11:46
x620 after flash with nspro phone dead ebu mohammed-emin NSPRO 6 01-29-2007 05:56
Page generated in 0.23239 seconds with 11 queries
