05-27-2006, 10:58 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, software for v690 will be uploaded in support area in some time. Cable: the same as v878 If you have v690 on hands pls try to read flash (like v878) and send it to [email protected] |
05-28-2006, 03:11 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | ay ay ay apo met! how could i read flash if i dont have the correct pinout does not connect with LG7050 cable any way thanks, ill try to figure out why it does'nt connect then send you flash! |
05-29-2006, 05:11 | #6 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | COM9 selected Device: V878 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... SW ver: I ^ ! HW ver: _7 Check Flash Done Check Parameters... Part 1 of 2... In progress... I WAITED FOR 1 HOUR reading this V690 flash but progress bar stay at 0% whats wrong boss? |
05-29-2006, 05:58 | #7 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | COM9 selected Device: V878 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... SW ver: I ^ ! HW ver: _7 Check Flash Done Check Parameters... Part 1 of 2... In progress... File saved: Backup_full_part_1_of_2_2006-5-29_12-28-32.3BX.bin Part 2 of 2... In progress... File saved: Backup_full_part_2_of_2_2006-5-29_13-2-52.3BX.bin Err: FLASH NOT DETECTED Err: FLASH NOT DETECTED Finished Remove/Install battery now ! Time used: 3261 sec |
05-29-2006, 07:41 | #8 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | V878 COM9 selected Device: V878 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Write: Images Write: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1080-000 HW ver: TCH-5- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881200010001 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0089:881200010001 Write: Flex Flash: 0089:881200000000 Write: Language Pack Flash: 0089:881200000000 Flash: 0089:881200000000 Write: FFS/File system Write: Images Write: Melody Writing Done Finished Remove/Install battery now ! Time used: 1906 sec V878_Main_5_1150_000_2004-Mar-22[1].3BM infinity team do you have firmware other than this ......i think its not complete when you go to menu labels are crazy...... |
05-29-2006, 08:07 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Use set of files: English, Chinese, Thai, VietNam, Indonesia, Melayu, Tagalog V878_Main_5_1040_2004-Jan-02 V878_LP_1010_004_T671KX_M2.0_V12_En_Cn_Th_Vn_Indon esia_Ml_Tagalog V878_Flex_1010_015-M2.0_V12_T671LV V878_Images_1010_004_T671KX_M2.0_V12 V878_Melody_1010_001_T671NM_M2.0_V12 English, Chinese, Thai, VietNam, Indonesia, Melayu, Tagalog V878_Main_5_1150_000_2004-Mar-22 V878_LP_1060_004T671KX_En_Cn_Th_Vn_Indonesia_Ml_Ta galog V878_Flex_1100_010_T671LC V878_Flex_1100_011_T671LD V878_Flex_1100_012_T671LE V878_Flex_1100_014_T671LU V878_Flex_1120_013_T671LT V878_Images_1050_004_T671KX V878_Melody_1030_001_T671NM English, Chinese, Thai, VietNam, Indonesia, Melayu, Tagalog V878_Main_5_1060_2004-Jan-14 V878_LP_1020_004_T671KX_En_Cn_Th_Vn_Indonesia_Ml_T agalog V878_Flex_1050_020_T671MA V878_Images_1050_004_T671KX V878_Melody_1030_001_T671NM |
05-29-2006, 08:58 | #10 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | COM1 selected Device: V878 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1060-000 HW ver: TCH-5- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881200010001 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0089:881200010001 Write: Flex Flash: 0089:881200000000 Write: Language Pack Flash: 0089:881200000000 Flash: 0089:881200000000 Write: FFS/File system Writing Done Finished Remove/Install battery now ! Time used: 421 sec thanks i used this and it worked fine V878_Main_5_1060_2004-Jan-14[1].3BM flashing with unibox takes only 421 seconds while on usb of infinity takes 3 times longer.........hehehehe wierd usb |
07-12-2006, 12:29 | #11 (permalink) |
Registered User Join Date: Aug 2005 Location: www.siamgsmunlock.com
Member: 175926 Status: Offline Thanks Meter: 25 | i send file moto v690 thai but this file not good i think becouse can not take camera but VDo can contact me msn; [email protected] Last edited by janjaroen; 07-12-2006 at 13:24. |
07-13-2006, 22:27 | #13 (permalink) |
Member: 175926 Status: Offline Thanks Meter: 25 | i read file moto v690 from my phone (thai lang)and i want sent to infinity team but my phone have probplem.can not take camera but can take VDO .i think my phone solfware problem.if you want this file contact me. and i want fullflash v690 thai lang.thank |
07-15-2006, 19:07 | #14 (permalink) | |
Send backup to [email protected] | |
09-22-2006, 11:29 | #15 (permalink) |
No Life Poster Join Date: Jun 2005 Location: naga city Age: 48
Member: 152821 Status: Offline Thanks Meter: 67 | Infinity TEAM what should I do with my Motorola v690 camera problem,video capturing is working but cannot take picture.all you can see is XXX in the picture gallery.hope you will enlightenh me on this.thanks. |
Motorola V690 -> V600 | CyberGSM | Motorola ODM | 2 | 10-12-2004 12:05 |
flash files for v878/v690 | baomobile | Motorola ODM | 0 | 09-19-2004 07:24 |
Motorola MPX200, V690 and V878 unlock via IMEI number! | .:: unlocker ::. | Main Sales Section | 0 | 08-20-2004 20:19 |
V690 firmware | little bunny | Motorola ODM | 0 | 07-16-2004 14:29 |
Wallpaper & New polyphonic ringtone 40 for Moto V690 | Timmer | Motorola ODM | 0 | 03-09-2004 02:58 |
