02-15-2009, 08:07 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: GSMPHILIPPINES
Member: 580978 Status: Offline Thanks Meter: 35 | v9+i format success flash files send to infinity support format logs not saved read fullflash COM67 [VCP0] selected module v2.76 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B6C9:B919 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9177B3C0.[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN_E44BE6BC].rpl ==================== New firmware detected (v.2.76, database date: 01.02.2009): NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 9177B3C0 identification#1 protocol ver: 04 ver. sw 1: NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN ver. sw 2: 086092_601_V9056, 4319B41B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN]... file saved: C:\Documents and Settings\admin\Desktop\flash[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN]_20090215-124214.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9177B3C0_NEOTEL26_06B_PCB01_GPRS_MT6226_ S01.086092_601_V9056.BIN_E44BE6BC_20090215-124236.B0X.bin Finished, time used: 2375 sec Remove/Install battery now ! http://w1.uploadmb.com/dw.php?id=1234595487 read fulflash/flashfiles flash[NEOTEL26_06B_PCB01_GPRS_MT6226_S01.086092_601_V905 6.BIN]_20090215-124214.B0M.bin module v2.76 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B6C9:B919 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 086092_601_V9056 Version: NEOTEL26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35044801123456 connection Ok building list... done items to clear: 154 warning: wrong packet cs items cleared: 150 of 154 items remains: 0 Finished, time used: 46 sec Remove/Install battery now ! COM67 [VCP0] selected module v2.76 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 135791246811220 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B6C9:B919 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 086092_601_V9056 Version: NEOTEL26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35044801123456 connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification done: 13579124681122 Finished, time used: 11 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to marcdashale3126 For This Useful Post: |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
plz send e 6233 flash file tested ok full flash file send me | faheemkhan | MT-BOX | 0 | 07-05-2009 08:48 |
5310 new firmware detected send to infinity support | marcdashale3126 | Infinity-Box | 5 | 02-22-2009 19:30 |
I808 error in format want flash file didnot find in support | urromeo | Infinity-Box | 1 | 08-03-2008 21:44 |
how to send file to infinity supporter | jignesh269 | Infinity-Box | 1 | 03-06-2008 19:28 |
