vadafone 125 unlocking error....help YellowBoss COM4 [VCP0] selected module v1.77 Device: LG-GB125 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB125_eeprom-static_20100517-011045.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB125_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100517-011045.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB125_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100517-011046.B1E.bin backup critical area Done Check memory ... loading data... data loaded error: can't read codes Finished, time used: 39 sec Remove/Install battery now !aca |
in your title you mentioned vodafone 125. see what you selected in your log: Device: LG-GB125 |
i select vadafone 125 then run pana01.exe then show lg -GB125 ? help YellowBoss plzzzzzzzzz |
i select vadafone 125 then run pana01.exe then show lg -GB125 ? help YellowBoss plzzzzzzzzz . IS TRUE THAT WHEN YOU CHOISE ZTE 125 AUTOMATICALLY THIS MODELlg 0F-GB125 DI SPLAYED ON THE PLACE OF ZTE 125 WHY THIS SO ? MY SELF I HAVE FACED THAT PROBLEM . |
firmware database date: 02.05.2010 Loading data, wait... smart-card: connected S/N: >>>>>>> Wait... Device: LG-GB125 Ready Device: ZTE-125 |
How do i unlock a vodafone 125 |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
