vairy Touch II phone lock code, how to remove? i tried to reset my tmobile vairy touch zte N281 but i got error always... http://i207.photobucket.com/albums/b...07/zten281.jpg Quote:
Hello, Try with latest MModule 3.79. Wr. |
In some cases it's need to use test-points cable for this phone (Rx/Tx/Gnd points at phone back side under battery). Also, try to press and hold phone "Power" button more long time. |
problem solved after updating main and mm module.... http://i207.photobucket.com/albums/b...2007/vairy.jpg Quote:
Is it was cable via phone connector or cable via test-points at phone back side ? |
via TEST_POINTS at phone back side... br, |
works iv updated to latest version nd it worked.... thanxxx BR ....HAMIDRAJA |
How to unlock this model? |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
