Old 03-08-2011, 09:18   #1 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 259
vairy Touch II phone lock code, how to remove?
i tried to reset my tmobile vairy touch zte N281 but i got error always...
logs:
COM54 [Serial2] selected
module v3.75
Action: "user code"
unlock method: smart fast
Model: ZTE-N281
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
error: operation failed !
Finished, time used: 1 min 32 sec
Remove/Install battery now !
br,
Old 03-08-2011, 09:25   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,018
Hello,
Try with latest MModule 3.79.
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-08-2011, 09:45   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
br,
Hello,
In some cases it's need to use test-points cable for this phone (Rx/Tx/Gnd points at phone back side under battery).
Also, try to press and hold phone "Power" button more long time.
Old 03-08-2011, 09:51   #4 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 259
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Wr.
sir i got the same error...
Old 03-08-2011, 09:57   #5 (permalink)
Member: 130995
Hello,
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-09-2011, 06:04   #6 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 259
problem solved after updating main and mm module....
COM8 [VCP0] selected
module v3.79
Action: "user code"
Model: ZTE-N281
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: TMO_UK_P107A3V1.0.1B10
Version: 09AZTENJ35_09A
83 byte(s) read
imei: 35769203316782
connection Ok
189 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
user code set to: 0000
Finished, time used: 21 sec
br,
The Following 2 Users Say Thank You to nelsky For This Useful Post:
Old 03-09-2011, 21:24   #7 (permalink)
Member: 130995
br,
What cable you have used for this operation ?
Is it was cable via phone connector or cable via test-points at phone back side ?
Old 03-10-2011, 00:28   #8 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 259
hi
via TEST_POINTS at phone back side...
br,
The Following User Says Thank You to nelsky For This Useful Post:
Old 03-14-2011, 18:55   #9 (permalink)
Member: 1212347
Thanks Meter: 16
works iv updated to latest version nd it worked....
thanxxx
....HAMIDRAJA
Old 03-15-2011, 18:39   #10 (permalink)
Member: 97044
Thanks Meter: 41
How to unlock this model?
Old 03-17-2011, 22:57   #11 (permalink)
Member: 130995
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Page generated in 0.34167 seconds with 8 queries
