11-18-2008, 19:49 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Vento FW Pls.. (E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1) anyone has this phone..? i need fullbackup.. eeprom and flsah file... ver. sw1: E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN ver. sw2: E551_C7TURKBT2.01.1, 1D5F52DE Code: COM14 [VCP2] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:AE9C:BBD9 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.53273641.[E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN_21ADA0E2].rpl ==================== New firmware detected (2.66) : E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 53273641 identification#1 protocol ver: 04 ver. sw1: E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN ver. sw2: E551_C7TURKBT2.01.1, 1D5F52DE ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\system_log_53273641_E551_C7TURKBT2_E551_GPRS_MT6226_S01.01_1.BIN_21ADA0E2_20081118-130410.B0X.bin Finished, time used: 198 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-18-2008, 20:06 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what problem with phone? did you try to solve it by formating FFS (safe or complete)? we dont have exactly same version in our collection, but have similar. for example: flashfiles/ChineseMiracle/_MT6226/E551_C7TURKBT3_E551_GPRS_MT6226_S01.01_1__ITEL_IT7 00_16m_En_Tr.B0M.bin worth to try them, but only after you backup your existing version (read full flash operation) other similar file you can find making search in support area, keywords is "E551_" here is example how to use support area search option: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
11-18-2008, 20:18 | #3 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
11-19-2008, 22:28 | #4 (permalink) | |
hi again... phone worked with this fw again.. "E551_C7TURKBT3_E551_GPRS_MT6226_S01.01_1__ITEL_IT 700_16m_En_Tr.B0M.bin" | |
Pls help me to get V195 FW file readed by FB3 | anhtam | Motorola P2k | 1 | 11-29-2006 23:49 |
W810 dead after flashing FW pls help | Andy187 | Cruiser Suite | 10 | 11-15-2006 14:53 |
Upload D520 FW into support area, pls. | kasner | UST Pro II | 13 | 05-19-2006 19:38 |
W900i dead when tryin to Flash Main FW!pls see the error!!! | ReyTech | Cruiser Suite | 4 | 03-30-2006 16:56 |
6270...Flash,tools,fw?Need pls | dj_markom | Nokia Hardware & Hardware Repair | 0 | 01-15-2006 09:43 |
