Old 06-07-2007, 13:42   #1 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
Veptu 8088 pinout
as intitled-i need pinout for veptu 8088
i tride to find in doccumentatation but can`t find
THX in advance
Old 06-07-2007, 14:19   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 32,673
Hello,
Please, check this:
http:///vbb/showpo...36&postcount=7
Old 06-07-2007, 15:34   #3 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
well,i`ve managed to find out the pinout,will post it later cause the phone is curently on box
i`ve read the eeprom and full flash,also read the detailed information,and now ,after flashing the phone is dead.
now returning the backupo and will see what happens
this is my first encounter with chinese miracle models and sincerly i`m a little bit confused,even though the manuals
is the flash file on the support area enough to repair a Veptu that didn`t show incoming calls?
the backup file is 10,0 MB and the flash file is 8,5MB,is it ok?
Old 06-07-2007, 15:56   #4 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
phone is alive again,after restoring the backup,but with the same problem-incoming calls are displayed only after call is ended
any suggestions?
thx in advance
Old 06-07-2007, 16:04   #5 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
Software :
1.Try to find good flash file in support to write it.
2.Format phones (90% problem software can repair by format)
Hardware
In my opinion , 90% problem hardware of chinese miracle is CPU.
you can check battery, reball CPU, dont care CPU can die. It's very strong.
Old 06-07-2007, 16:48   #6 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
problem solved with formatting
thx a lot
but still-i would like to know how to sucessfully flash this phone,for other cases
is the only way trying file after file?
Old 06-07-2007, 17:22   #7 (permalink)
Member: 130995
@Rhamses
the only way: your experience and phone firmware/file name.
btw, pls, post here pinout that you have found, it will be useful for other people.
Old 06-07-2007, 18:02   #8 (permalink)
Rhamses's Avatar
Member: 23848
Thanks Meter: 13
must appologize but sincerly i`ve forgot to write down and i`ve already gave the phone to the *******r
i`ll try to remember
it was a 8 pin connector
keyboard
\________/
1......8
1-Charger
6-TX
7-RX
8-GND
If this is wrong try inverting RX and TX
sorry,my mistake for not writting it down earlier
Greetings!
Old 11-26-2007, 08:47   #9 (permalink)
Member: 202611
Thanks Meter: 51
this one is wrong mate gnd-1, tx-2, rx=3 tested and aproved by me
by bicco
Old 11-26-2007, 08:58   #10 (permalink)
Member: 202611
Thanks Meter: 51
COM7 [VCP4] selected
19200
Initializing[6219:8A01]...
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6219,E01
Date: 2004.06.18
Version: 1.7.1.2
Version: M300.05.24.V18
Version: E01_HW
detecting structure #2...
done
imei: 13579024681122
connection Ok
detecting structure #1...
error: detection failed, read flash and send to support
Operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
why i cant unlock this phone NARNIA 8088 when i try to formate it format well all 2 way but phone problem is when u power it it works but after few minuts it ask u passowerd and a short time will power off it self
Old 06-01-2009, 06:45   #11 (permalink)
Member: 157567
Hi I have the solution you dont even need to flash it at all. just enter the codes will do to solve that problem. Please Input password! QQ122586853 (Solution!). that will solve all this problems. Hope this helps.
veptu i70 firmware flash files mt6219at ..::UFUK26::.. Chinese Models & Cloned Phones 5 02-18-2009 15:39
Veptu Firmware or themes.. scotcruz Various 0 09-27-2007 18:12
8088 call records problem Laser Motorola Old Legacy (EMMI) 1 02-17-2003 04:47
Need 8088 flash dennt Motorola Old Legacy (EMMI) 0 04-27-2002 18:35
Motorola 8088 vato Motorola Old Legacy (EMMI) 2 05-20-2001 23:03
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.43879 seconds with 8 queries
