12-20-2008, 11:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 70460 Status: Offline Thanks Meter: 10 | Vertu Ascent-Ti-RM-267V pinouts here connector_2x5_mini, keyboard top _______________ | 1 2 3 4 5 | | 6 7 8 9 10 | ----------------- 6 gnd 4 tx 9 rx IKRON. |
The Following 3 Users Say Thank You to ikron For This Useful Post: |
02-13-2009, 19:04 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
02-20-2009, 14:12 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 105817 Status: Offline Thanks Meter: 133 | Vertu ascent TYPE RHV-3 CONECTOR-5 PIN(5310usb) PINOUTS THERE result: Rx:2 Tx:3 time required: 2 sec Power On ! |
The Following User Says Thank You to ekrem For This Useful Post: |
07-30-2009, 19:01 | #8 (permalink) |
Registered User Join Date: Mar 2006 Location: Hungary Age: 50
Member: 245884 Status: Offline Thanks Meter: 21 | Please help Anybody! I have Chinese Vertu Ascent-Ti-RM-267V DUAL SIM and need pinout. 2*5 pin connector.I read before other side any idea,but not work (6 GND,4 TX,9 RX) B.R. doktormobil |
07-30-2009, 22:01 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. | |
11-18-2009, 22:04 | #10 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | hi i have also "vertu" Ascent-Ti-RM-267v single simcard and strange socket , 12pins --the size is "between micro usb and samsung e250" maybe you have some pinout?or which cable i must use?thanks a lot |
11-20-2009, 13:32 | #12 (permalink) | |
Major Poster Join Date: Sep 2009
Member: 1123097 Status: Offline Thanks Meter: 5 | Haosung N3000 pinout???? Quote:
When I have the multimeter, how do I find the GND pin? Is it the negative pin that the battery attaches to? Your quote below isn't too clear for me as I'm new to this. Should the battery be attached to the phone? Can you give me a more detail way of doing it? I don't have a box, I want to buy a cable from ipmart to do it. | |
The Following User Says Thank You to Casanova2k8 For This Useful Post: |
11-21-2009, 17:04 | #14 (permalink) | |
if you going to buy cable from ipmart - what is a point to search for pinout? | |
11-21-2009, 23:13 | #15 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | ok i will check it tomorrow but tell what is wrong with this adapter? i have alson next pieces of chinese phone that is iphone mini with mt 6225 and l12c connector and the same problem 19200fixed and can't find pins also when i give him "infinity data base pinout". phone 100% in good condition brand new box |
Vertu Ascent Ti, RM 267v | freeman 2008 | Nokia Hardware & Hardware Repair | 7 | 01-13-2015 21:22 |
Chinese-Vertu Ascent Ti-RM-267v | asarmen | Chinese Models & Cloned Phones | 4 | 04-26-2010 09:54 |
Vertu Ascent-Ti-RM-267V EASY PINOUT here | jawad8305 | Infinity-Box | 1 | 03-12-2010 08:24 |
Chinese-Vertu Ascent Ti-RM-267v flash file | alexmkdMAFIA | Chinese Models & Cloned Phones | 2 | 12-20-2009 23:15 |
Vertu Ascent Ti, RM 267v | freeman 2008 | Various | 2 | 05-07-2009 22:10 |
