very angry from u infinity team in the first post i told you about a chinese phone .. i was only need to format it .. u replied on me .. i did what u said .. the result : phone dead first post now .. i tried to change language for another phone .. i made a search on ur support .. the flash i need was : BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN i made a search on ur support .. i found this : flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Cect-N95_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07_16m_ En_Cn_Cn_Ar.B0M.bin i have flashed the phone with it ... the result : phone is dead for the second time in 2 days infinity killed phones .................................................. .................................. what i'll do >>>>>?????????? |
learn, and learn, and learn... If you got an ugly face, so would you break your own mirror? :p |
i didn't want a reply from you .... :confused: i sent this message to the infinity supporters |
and it can be happend in software dont worry try to find the same model around you read flash and make alive your dead phone |
hi, just to remind you, always have fullbackup from your phone before doing any procedure. write it back if anything happen to your phone. |
@c_ahmad79 thanx for ur reply but i have not got any same phones and i wanna say that .. i used a flash file from the support how it made the phone dead i don't know ?? i always use the infinity box .. but i'm angry because two phones dead in 2 days fror the first time with me ... all i want to know .. why???? |
there is many chinnese phone, and there is many model look same and they got diffrent firmware sometime. |
@ mentari i want u to read this page because i'm working as they said in it and i think it's succesfull .. this is not the first time for me One Method for Find Flash File in Infinity Support Site |
hello! regarding first phone: dead phone is not worse or better than restarting. just dont stop in the middle of process. Post here phone's original software version, we will try to advice correct flash file. regarding second phone: post here flashing with wrong file LOG. will try to analyse what went wrong |
look man if u dont know how to treat with chinese phones so u better stop working with it , stop plaming on another one for ur own mistake and with all that InfinityHelp wants to help u and told u (post here formating log. we will check original sofware version and advice flash file) that mean that they will search for u for a flash that can make ur phone alive again where is the details that they asked u??? am sure that u cant even find it in ur ouw computer so,,,,, stop spam and treat with ur mistakes as a man BR, Elkawasmy |
and who r u ?????? u don't know any thing for talking ... i said this is a message for the infinity supporters ... @ infinity help ... thanx for reply i'll send u the logs |
COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:B9C1:130E high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E9F743C0.[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN_6C16 8827].rpl identification#1 detection finished device-id: E9F743C0 identification#1 protocol ver: 04 ver. sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN ver. sw2: BR26_05.07, D877E993 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00FC0000 Detected eeprom/ffs address is non-standard: 00FC0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00FC0000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:00FC0000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07.BIN]_20080423-170126.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E9F743C0_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_0 7.BIN_6C168827_20080423-170250.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E9F743C0_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_0 7.BIN_6C168827_20080423-170303.B0X.bin Finished, time used: 238 sec Remove/Install battery now ! |
first: read eeprom (ffs) & flash (firmware) same model of this phone. second:first write eeprom(ffs) then flash (firmware). phone will be ok 100%............ |
If it is .. N95 PDA ... then tell me ... i have the working backup of the Phone..... |
