07-19-2008, 23:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183976 Status: Offline Thanks Meter: 134 | A very big problem with chinese miracle ... 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! when i try to read detailed information i have that : 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! |
07-20-2008, 07:30 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
07-20-2008, 11:16 | #6 (permalink) | ||
Member: 183976 Status: Offline Thanks Meter: 134 | Quote:
08-06-2008, 14:15 | #9 (permalink) |
Member: 183976 Status: Offline Thanks Meter: 134 | pinout are writed on the pcb of the phones and cable work very good with non chines mobiles (for example i used the cable and a chines cable to unlock some LG KG275 today) |
very big problem with 7610 | nofear197979 | WD2 & APE (Symbian Phones) | 25 | 08-14-2008 22:14 |
I have VERY VERY realy VERY BIG!!!! problem with signal | Lipper | NEC | 7 | 06-29-2006 21:43 |
Motola MPX200 very big Problem with unlock CODE | winiu | Motorola ODM | 6 | 02-02-2006 18:44 |
Julvir... very very big problem with C4-2 | Spalato | Redbox | 1 | 12-30-2005 00:31 |
HELP!Very big problem with network on S300 - SOFT or HARDWARE?????? | bolt_gsm | Trident/AGERE Platform | 1 | 09-07-2003 07:48 |
