01-25-2012, 04:10 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: United States
Member: 376302 Status: Offline Thanks Meter: 30 | Verykool i270 Dead COM133 [VCP0] selected module v4.13 Device: Verykool-i270 Checking data, wait... Action: write flash NAND write: Firmware Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54_2010-01-05_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: LC1AE09.6.3.1.2T16M1201_MB54 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T16M1201_MB54.BIN project-id: LC1AE09.6.3.1.2T16M1201_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... Disconnect... done Finished, time used: 30 min 57 sec Remove/Install battery now ! |
02-01-2012, 03:10 | #5 (permalink) |
Member: 376302 Status: Offline Thanks Meter: 30 | Operation Log Loading data, wait... [Infinity Box] MModule v4.09 smart-card: connected S/N: 9ECD:0118 Wait... trying to select model: /I270 model selected via command line: Verykool-i270 Device: Verykool-i270 Initialization done ==== [24/09/2002 1:00:44] ==== COM10 [VCP0] selected module v4.09 Action: read unlock codes unlock method: read codes Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 52 sec Remove/Install battery now ! ==== c:\InfinityBox\MModule\MModule.exe [24/09/2002 1:06:57] ==== Infinity-Box - Multibrand Unlock & Repair Tools Loading data, wait... [Infinity Box] MModule v4.09 smart-card: connected S/N: 9ECD:0118 Wait... trying to select model: /I270 model selected via command line: Verykool-i270 Device: Verykool-i270 Initialization done method is not supported yet method is not supported yet WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [24/09/2002 1:09:32] ==== COM10 [VCP0] selected module v4.09 Device: Verykool-i270 Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: LC1AE09.6.3.1.2T19M0105_MB54 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T19M0105_MB54.BIN project-id: LC1AE09.6.3.1.2T19M0105_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done Format... 00000000-03FFFFFF... Format done Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54__system_log_20020924-011125.B4X.bin Finished, time used: 2 min 3 sec Remove/Install battery now ! Flash phone with firmware from support area ! ==== c:\InfinityBox\MModule\MModule.exe [24/09/2002 1:48:00] ==== Infinity-Box - Multibrand Unlock & Repair Tools Loading data, wait... [Infinity Box] MModule v4.09 smart-card: connected S/N: 9ECD:0118 Wait... trying to select model: /I280 model selected via command line: Verykool-i280 Device: Verykool-i280 Initialization done Device: Verykool-i270 Flash phone with firmware from support area ! Flash phone with firmware from support area ! Device: Verykool-i280 Loading file v.05... ==== c:\InfinityBox\MModule\MModule.exe [24/09/2002 2:47:12] ==== Infinity-Box - Multibrand Unlock & Repair Tools Loading data, wait... [Infinity Box] MModule v4.09 smart-card: connected S/N: 9ECD:0118 Wait... trying to select model: /I270 model selected via command line: Verykool-i270 Device: Verykool-i270 Initialization done Loading file v.05... Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T16M1201_MB54_En_Es.B4M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T16M1201_MB54.BIN project-id: LC1AE09.6.3.1.2T16M1201_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [24/09/2002 2:47:40] ==== COM10 [VCP0] selected module v4.09 Device: Verykool-i270 Checking data, wait... Action: write flash NAND write: Firmware Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T16M1201_MB54_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: nand header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash (39): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 13 min 13 sec Remove/Install battery now ! Loading file v.05... Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54_2010-01-05_En_Es.B4M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T19M0105_MB54.BIN project-id: LC1AE09.6.3.1.2T19M0105_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [24/09/2002 3:01:41] ==== COM10 [VCP0] selected module v4.09 Device: Verykool-i270 Checking data, wait... Action: write flash NAND write: Firmware Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54_2010-01-05_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: LC1AE09.6.3.1.2T16M1201_MB54 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T16M1201_MB54.BIN project-id: LC1AE09.6.3.1.2T16M1201_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash (3): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54__system_log_20020924-030414.B4X.bin Finished, time used: 2 min 37 sec Remove/Install battery now ! ==== [24/09/2002 3:08:03] ==== COM10 [VCP0] selected module v4.09 Device: Verykool-i270 Checking data, wait... Action: write flash NAND write: Firmware Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T19M0105_MB54_2010-01-05_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: LC1AE09.6.3.1.2T19M0105_MB54 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T19M0105_MB54.BIN project-id: LC1AE09.6.3.1.2T19M0105_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... Disconnect... done Finished, time used: 31 min 11 sec Remove/Install battery now ! ==== [24/09/2002 3:40:24] ==== COM10 [VCP0] selected module v4.09 Action: "sp-unlock" unlock method: smart fast Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0004:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 35 sec Remove/Install battery now ! method is not supported yet WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? aborted by user ==== [24/09/2002 3:41:26] ==== COM10 [VCP0] selected module v4.09 Action: "sp-unlock" unlock method: smart fast Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0004:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware 52 byte(s) read warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs connection Ok 165 byte(s) read reading data... warning: wrong packet cs reading data #2... warning: wrong packet cs reading data #3... warning: wrong packet cs reading data #4... warning: wrong packet cs reading data #5... warning: wrong packet cs Unknown or damaged lock structure, what to do: 1. repeat operation and press and HOLD "Power" button more long time 2. use another unlock method, f.e. "unlock method: standard" 3. if nothing helps: read flash and send to support: [email protected] error: operation failed ! Finished, time used: 28 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? aborted by user method is not supported yet WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [24/09/2002 3:42:16] ==== COM10 [VCP0] selected module v4.09 Action: reset settings ("format ffs") Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0004:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware 52 byte(s) read warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs connection Ok warning: wrong packet cs building list... done no items found warning: wrong packet cs warning: wrong packet cs error: operation failed ! Finished, time used: 36 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [24/09/2002 3:43:05] ==== COM10 [VCP0] selected module v4.09 Action: reset settings ("format ffs") Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0004:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware 52 byte(s) read warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs connection Ok warning: wrong packet cs building list... done no items found warning: wrong packet cs warning: wrong packet cs error: operation failed ! Finished, time used: 34 sec Remove/Install battery now ! Loading file v.05... Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T16M1201_MB54_En_Es.B4M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T16M1201_MB54.BIN project-id: LC1AE09.6.3.1.2T16M1201_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 ==== [24/09/2002 4:12:27] ==== COM10 [VCP0] selected module v4.09 Device: Verykool-i270 Checking data, wait... Action: write flash NAND write: Firmware Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T16M1201_MB54_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: LC1AE09.6.3.1.2T19M0105_MB54 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_2T19M0105_MB nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 04 sw version: LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_6_3_1 _2T19M0105_MB54.BIN project-id: LC1AE09.6.3.1.2T19M0105_MB54, C738B993 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: LCBJ30_07A_PMJ_BOOTLOADER_V005_MT6229_LC1AE09_6_3_ 1_1T12M1113_MB nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash (5): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Last edited by InfinitySupport; 06-27-2020 at 20:19. Reason: legacy links cleanup |
02-01-2012, 03:37 | #6 (permalink) |
Member: 376302 Status: Offline Thanks Meter: 30 | I270 full Backup Backup another phone before make unlock, after unlock phone restarting with sim no original, with original sim work fine this is log unlock COM133 [VCP1] selected module v4.13 Action: "sp-unlock" unlock method: smart fast Model: Verykool-i270 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0001:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2000.00.00 Version: 1.0 Version: LC1AE09.6.3.1.2T16M1201_MB54 Version: LCBJ30_07A_PMJ_HW 52 byte(s) read imei: 35646202042166 connection Ok 165 byte(s) read reading data... reading data #2... warning: wrong packet cs building new data... writing data... warning: wrong packet cs 153 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 20 sec Remove/Install battery now ! Backup original Verykool-i270_LCBJ30_07A_PMJ_PCB01_GPRS_MT6229_S02.LC1AE09_ 6_3_1_2T16M1201_MB54__firmware_20120201-025409.B4M.rar - 4shared.com - online file sharing and storage - download Security Backup before Dead Phone http://www.4shared.com/rar/yIPs01Hm/..._security.html |
02-03-2012, 14:24 | #7 (permalink) |
Member: 376302 Status: Offline Thanks Meter: 30 | Verykool I270 Restarting I need from infinity Support help now have 2 Verykool i270, one total dead and one allways restarting and one customer wating. |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
